Surprisingly, the Shifter Is Intuitive To Use - 2014 BMW i3 Long-Term Road Test
edited March 2015 in BMW
imageSurprisingly, the Shifter Is Intuitive To Use - 2014 BMW i3 Long-Term Road Test
The unusual column-mounted shifter in our 2014 BMW i3's is surprisingly easy to use.
  • adamb1adamb1 Member Posts: 122
    Up would be twisting toward the front of the car, down would be twisting toward the rear of the car. Seems correct to me.
  • yellowbalyellowbal Member Posts: 234
    Neutral in the middle, that actually makes more sense than normal automatics. Manuals always have neutral in the middle.
  • voshinskivoshinski Member Posts: 6
    I think the shifter befits the vehicle but one question, you said "while parallel parking" but I thought this car could park itself?
  • schen72schen72 Member Posts: 433
    I also thought Benz's column shifter would be confusing to learn, but it's surprising intuitive and easy. Within just a few minutes of driving, it felt very natural to me. There's also the benefit of freeing up a lot of space in the center console.
    Or you could just use the column shifter. Thankfully Ford and GM still stick with the tried and true. Never understood the need for the Germans to intentionally make simple things complex.
  • mcesareymcesarey Member Posts: 11
    This is much like a forklift. This would actually be perfect for parallel parking.
  • anotherdrunkanotherdrunk Guest Posts: 30
    edited March 2015
    i like to fly out of the driveway in reverse
    bang D forward
    and feel the smooth electric transition
    versus
    what would happen doing that in old school transmission
