Corvette C6 6 Speed transmission malfunctioning
durn1durn1 Member Posts: 1
edited March 2015 in Chevrolet
hello! I just bought a 2008 c6 corvette and sometimes when I'm shifting from 1st to 2nd gear it gets stuck and I kinda have to fight it to get it out. If you have any idea what would be causing this please let me know. Thanks!!
Best Answer
Answers
  • thecardoc3thecardoc3 Member Posts: 5,856
    What happens if you shift the transmission between gears with the engine not running and the clutch disengaged? (pedal held to the floor) What happens if the engine is running but the car is not moving? Does that change its tendency to stick? Is there any noise from the transmission during acceleration or coasting? When it sticks does tapping and releasing the throttle without disengaging the clutch allow it to shift out of gear?
