More Gauges, Debatable Usefulness - More Refined But Still Plenty Fun
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
Our 2015 Ford Mustang GT has plenty of information available through its gauges. But it is debatable on how useful this information is.
If this was an Audi the title of the post would have been: "Readily available and useful engine operation information at a glance or push of a button."
I would suggest that the 2 post titles looked at side by side: "All the gauges you need" for the Murano vs. "More gauges. Doubtful usefulness" for the Mustang shows the anti-domestic brand bias ingrained in the people working for the Edmunds site. I would suggest attempting to disassociate the brand name from the vehicle being evaluated. For example why did it take so long to inform us readers that the BMW i3 has a lousy ride over a bumpy road?
did you guys try using the track apps during testing to see how accurate they were as compared to your hifalutin gps stuff?
It could very well be possible the Mustang has a real oil pressure sender, but there's also a chance it doesn't. Not showing actual numbers on the oil "temp" gauge would have be very suspicious that at least that digital gauge is just a calculated estimate anyway. While I don't mind extra data and gauges in a performance model there is such a thing as data overload, which is worse if they're dummy gauges and don't read true (like most coolant gauges that immediately park in the mid-point and don't move to prevent normal, non-car savvy people from thinking something is wrong with their car just because it fluctuates).
Accurate voltage gauges would be difficult on a modern car too. To save fuel, computers increase alternator output while coasting and decrease it while not. The computer knows if the commanded alternator output doesn't match the actual and will turn on a warning light. But if your gauge was fluctuating between 12-15 volts, how would you know when it's supposed to be where and if that actually indicates a problem? Which is why vehicles that still have voltage gauges pin them at "normal" just like their temperature gauges.
Same with oil pressure. The computer knows what it should be at any given RPM. 99.9% of the people driving don't. A fluctuating gauge doesn't provide useful information.
All those gauges in the Mustang are for mere entertainment. It's a modern car, not an airplane.
