Why does my Bonneville not idle by itself then sometimes works great?
                    So it willit will be running fine And when I hit the brakes it will die once the rpm Get to 1 . If I keep the gas on And don't let it get to low it will stay running. it will do that for a while And then work fine.  Some days it won't idle when you first start it But as long as you manually keep it going it will. I changed the throttle position sensor,crankshaft sensor,wires,plugs,battery anxious alternator are Good. I am at a loss. it has 246000 on it.
Answers
Has the upper intake "plastic" manifold been replaced? I have read
of vacuum leaks around the bottom seal with age. That changes with
temperature so it gives odd symptoms. With engine idling you can
spray carb cleaner around the edges and around hoses to see if you've
got a vacuum leak sucking in air.
Has the throttle body been cleaned to remove the gunk
that builds up around the butterfly plate which can affect the idle?
Has the IAC (idle air control) been cleaned? Do not dip it but it may
have carbon around it, both in the opening it sits in and on the pintle
of the valve.
Has the MAF been cleaned with a liquid spray to clean the dirt bits
that can end up on the two wires that measure the air flow rate?
The backyard check for the MAF is disconnecting it and seeing if the
problem goes away.
First, you've replaced several parts and they may not have been needed. Also,
the oxygen sensors that are off brand replacements sometimes are trouble them-
selves even though they are new. Only one of those sensors actually is needed;
the other one just serves as a check.
When the engine will not stay running, does it always start back up? If it doesn't,
you need to have removed a plug wire so it's easy to slip off again, put in an old
spark plug and lay it on metal of the engine. Have someone crank while you watch
for the spark you're getting across that plug. They also sell spark plug gadgets
that you can put on the wire to show a gap and let you check the spark color and
strength. If you're getting no spark while the engine will not restart, then crankshaft
position sensors wear out and the spark control module under the coils can also
give trouble, especially when hot.
If you've got spark then you may not be getting fuel.
Something to try is to remove the connector from the MAF and see if that
changes this problem. It may not be the MAF, but at least it's a place to
start.
Beyond that you need someone with a scanner that's able to look at the
mixture counts that the computer is using to go rich or lean and see what
is happening at a higher level of analysis.
Good luck. But you may need to have a good dealer analyze the problem
or a good shop that actually has the technology and the SKILL to analyze
what's going on.
will go off when you plug MAF back in. Do you have a friend with the same or similar car with which
you can exchange the MAF to see if the other known good MAF fixes your car's bad running?
I will do some reading a Bonneville forums to see what I can learn. If you should get a replacement
that you buy, get a good brand. I see rockauto.com has AC Delco for $171 plus shipping. There is a 5% discount number available on the internet that might save enough top pay the shipping. A Dorman
runs about $80.
Another thing to try for the idle problem is to unplug the MAP sensor. It's on top of the PCV housing.
If you unplug it an the problem goes away....
