Which Service Interval to Follow? - 2015 Kia K900 Long-Term Road Test
Edmunds.com
Our 2015 Kia K900 is ready for an oil change. Or is it?
I know most, if not all dealers move up the intervals and add services that the manufacture doesn't recommend but what is KIA's definition of normal driving?
"while Kia's manufacturer recommendation is 7,500 miles under normal use." makes me think it is a fixed interval.
which, again if their driving isn't considered 'normal' then the shorter duration would fit.
Now of course some will say that the dealer should know the right product to use in a given car and yes they should, but when it comes to quick lube practices and needing to hit certain profit numbers and the reimbursement that the dealer gets for the service there is a lot of room for someone to try to cut corners. This KIA likely requires at least API SN and ILSAC GF5 which is a great standard as compared to the SM/GF4 of just a few years ago. But SN and GF5 alone does not certify that it as a long life oil, in fact nothing in the API designates anything as long life. Only by choosing a product BEING APPROVED FOR additional requirements such as ACEA A5/B5, dexos, (and others) can do that.
Right now the OP should open the owners manual and record the specification that the engine requires, especially if there happens to be an additional requirement above the API and ILSAC ratings. If nothing is shown beyond the API SN and ILSAC GF5 then the OP has a choice. Go ahead and use a product that only meets that standard and hope that it doesn't fall short of the vehicle needs like what has happened in the past or go ahead and choose a product that is dexos approved. (The green label must be on the front of the bottle) Then go ahead and do the once a year oil change, or when ever the maintenance reminder triggers, which ever comes first.
BTW, in the event that the maintenance reminder is accidentally reset you must follow the heavy duty schedule as per the manufacturers guidelines and that window sticker is correct in its calculation to ensure a failsafe level of service. FWIW An alternative routine to the oil change sticker issuance would have the current date and mileage that the oil change was done listed on the sticker to avoid the scenario that this article is based on. Remember too that the oil change interval is also dependent on the filter that the engine requires, some systems are simply not designed to go as far as others.
