Overriding The Transmission for Emergency Towing - 2014 Ram 1500 EcoDiesel Long-Term Road Test
Edmunds.com
There's a way to put the 2014 Ram 1500 Ecodiesel's electronically-controlled transmission in neutral if the truck won't start and needs to be towed.
And most people in this kind of situation will be kinda flustered...making them go through this kind of song and dance is idiotic. When this truck stalled, you were in the driving lane...but on a little-used road, and you were able to restart it and move it to the curb, and then had 53 minutes to figure out this Rube Goldberg setup. So basically you lucked out. What if you had been on a major road, say, waiting for a green light, when it stalled, and you could not restart it - now it just sits there with traffic whizzing around it (hopefully not INTO it) while you peruse page 665 of the manual - hopefully from the shoulder of the road rather than the driver's seat? And what if the tow truck arrived to pull you out of the driving lane in 5 minutes, before you figured out this strap and lever arrangement?
And finally...why are you even saying in this post that you could not restart it - you clearly state in the original February 19 post that you were able to restart it, get it to the curb and shut it down. And since it restarted for the dealer, I imagine you probably would have been able to restart it after the tow truck arrived, if that is indeed required for the shift into neutral.
Too much of what you're saying here does not square with what you said in the earlier post.
But you're right, Dan could have refused the tow and demanded that they send a flatbed instead.
You could have the front wheels down and the rears lifted up (steering wheel has to be secured in some way) in 2WD with no damage, or you could just put the t-case in neutral and tow it in whatever position you please. But engine off means the oil pump in the transmission is off as well, with the wheels now turning your transmission with no oil pressure inside.
