Code 68 motor circuit malfunction for a Dodge Durango 2001
durangoguy2durangoguy2 Member Posts: 2
edited May 2015 in Dodge
code 68 motor circuit malfunction for a dodge durango 2001,. got this code and my abs/brake light is still on,.I have to the end of this Month of May to get my truck to pass an inspection ,..times running out ??
Answers
  • durangoguy2durangoguy2 Member Posts: 2
    My question is does anyone know how to correct this ??
  • thecardoc3thecardoc3 Member Posts: 5,856
    Yes. You have to first prove if the failure is in the motor (pump) portion of the ABS controller, the module section, or the wiring for it. If it is the module it can be repaired. http://modulemaster.com/rebuilds/
