LS What? - 1966 Chevrolet Corvette Long-Term Road Test
Edmunds.com
Edmunds conducts a long-term test of a 1966 Chevrolet Corvette Stingray and ponders the need to swap its original engine for a modern LS-based one.
Dyno it. Just remember there's no fuel cutoff and if you overrev it, you WILL be doing some expensive work on your numbers-matching engine. In this mild state of tune, the power peak will be all over and done with by around 5000, with the redline at 5500.
You folks stated in the initial post that the 300-hp engine was base; this is not so - the base 327 was 250 hp.
I think the one thing other than radial tires I would do to this car, due to 1) they are notable overheaters, 2) you are in Southern California with summer coming up, 3) car has A/C, which loads the engine when idling in traffic (SoCal, again), is get rid of that engine-mounted fan and mount a pair of Hayden thermostatically-controlled electric fans on the radiator. One of the most common mods for older cars that will be driven on the road.
doesnt mean its right
If you could take a new 2015 Stingray back in time I wonder what the engineers back in 1966 would say.
