Transmission - Hard Shift at low speed
My 2005 LeSabre has a "hard or rough shift" when I travel between 20 - 30 mph in "3rd gear", It's very noticeable. I checked the transmission fluid and there are small bubbles on the dipstick. The fluid level is normal. I will the check the fluid level again tonight. The LeSabre has 53,000 miles. Does anybody recognize this problem?
Best Answer
imidazol97 Member Posts: 27,132Has the transmission fluid ever been changed? If not, that would be a first step especially if you have someone to change it and NOT do a flush. Be sure to use the GM-recommended Dexron VI fluid, made by several companies.
The problem could be from old oil affecting the controls in the transmission. Changing might help after a few hundred miles.
However, does this problem come and go at times. Is it always shifting better after the car has been restarted and especially when the car has been started after sitting overnight? Does it shift nicely if you accelerate very briskly and just keep the pedal down as you start onto a highway, for instance, where the tachometer shows the engine speeds stay at 2500 or above?
It may be the PCM (pressure control module) that's not able to control the shifts at low speeds. Some of the better box stores, Advance Auto Parts, Autozone, will do a check for codes and their scanner can read the transmission codes, if any.
The PCM can be replaced for a few hundred dollars in labor IF THAT'S THE PROBLEM--the engine cradle has to be dropped slightly to get access easily to the side cover on the transmission on the driver side to replace the PCM.
If you find that driving briskly when accelerating helps, while idling through the shifts causes the long shifts which the PCM has trouble controlling shift times on and sets the trans in protect mode which does quick shifting to protect the clutches from wear, you have your answer. BTW, it takes 2 long shift times that are too gentle for the trans to go into default limp home mode.2014 Malibu 2LT, 2015 Cruze 2LT,
5
Answers
If I were in your place and you are able to do the pan removal yourself, instead I'd recommend getting a hand suction pump from Harbor Freight if you have a store nearby for $4.99 and put the suction tube down the dipstick tube all the way. Pumping will remove all 6 quarts of fluid that would have dropped out when you removed the bolts on one end of the pan to let it drain.
I'd replace that with 6 quarts of Dexron VI fluid (I just used Walmart's brand of trans fluid Dexron VI (Supertech blue bottle) for $4.27 each). Fill with 5 and and warm up the transmission then use last one to fill to just the full level when trans is hot.
Drive it for 5 K Miles or so. By then you'll know if you have a continuing problem or if clean fluid helped things move better inside the trans after some time to clean with the new chemicals in the Dexron VI.
THEN drop the pan and put a new filter on and replace 6 quarts with Dexron VI fluid. You will have replaced about 75% of the old fluid in the 2 changes with fresh Dexron VI.
Don't put in any additives. The first refill with fresh fluid with fresh cleaners will do any cleaning that additives might do. The old filter will catch any sludge loosened. Then you're replacing a filter that may have caught some goop with a nice fresh one--I use Purolator from Pepboys.
Page on link contains the $4.99 coupon for the pump. Click on print coupon to get actual coupon.
Get on their mailing list and they'll send you coupons--look for the ones where you get something free with any purchase!
Pick up a second hand pump with a duplicate coupon. The first one I had didn't last long. I don't think it liked the warm trans fluid I pumped out. Maybe should have let trans cool.
https://us-mg4.mail.yahoo.com/neo/b/message?sMid=8&fid=Inbox&sort=date&order=down&startMid=0&filterBy=&.rand=1467261453&midIndex=8&mid=2_0_0_1_447301_AEwNiWIAALt6VXYKLwluEPeTrQw&fromId=
Good luck. Please report back to me what happens.
