No fire to injectors
chig357chig357 Member Posts: 3
edited June 2015 in Pontiac
All my fuses are good just the injectors are not foreign none of them
  • chig357chig357 Member Posts: 3
    The fuel injectors are not fireing, like it had bad fuses but it don't. Cranks but won't start
    It might help the techs hanging around here to know what model '97 Pontiac you have.
    it's a 1997 Pontiac grand prix with the 3.8
    Which fuses did you check? #7 for the injectors and #8 for the PCM in the relay center? It's on the right side under the dash next to the glove box on the bottom of the A-pillar.
    You can feel an injector fire while cranking by touch. Or connect a small light bulb ?194? which just has wire leads across the connector that you take off the injector and crank to see if you see flashes.
    Are the spark plugs firing? Lay a plug on the engine with its wire connected while cranking and check for spark.
  • racing56racing56 Member Posts: 1
    edited July 2015
    I bought a 1992 grand prix se 3.4L that was built for racing and it is not wanting to start, it has fuel pressure and power to everything, I checked the power to the fuel injectors and it has continuous power with no break, which is not right, what is causing the this to do that and how can I fix it?
  • Fixmys10Fixmys10 Member Posts: 1
    This is an old topic but check the injector plug ins look inside them to make sure the contacts are in place
