P0457, P0456 Evap Control System Leak
libertyman1
Member Posts: 4
I went to the dealer the first time and they said it was a bad ESIM assembly. I replaced it and the gas cap with OEM factory parts and it did not fix the problem. I went back to the dealer and found the true cause on the second visit. The wire was coroded where where the wiring harness clips into the charcoal canister adjacent to where the ESIM is located. I would have found it my self if I had taken the time to carefully check the wiring harness at the connector clip.
I could replace the parts now myself but I don't want to burn the bridge with the dealer since I already don't give them much work. I go there for oil changes and they tell me about issues with my Jeep and most of the time I just fix the simple stuff myself. This one was harder to diagnose but I should have just looked over the wiring more carefully because it was green with corrosion at the connection clip. I hate the brine they use on the roads in Northern Ohio, it eats up the cars in as little as three years.
At that price the tech had about eighteen minutes to figure out the problem, and it's no where near as simple to do as some would like to believe. For one thing, a professional level tool can command the PCM to run a self test on the evaporative system and a solid diagnostic and repair routine would have the tech run that test, prove that the car has presented with a live problem, and then repeat the test while actively testing the ESIM manually. That routine would find the wiring issue the first time whether it really was the only fault or not. The time required to run the tests like this is going to be some twenty-five to thirty minutes. Since they don't get paid enough time to test completely, they get trained to risk short-cutting the diagnostics. From there when the tech does the repair, then they should run the test again and prove that the car was in fact repaired. That time is also supposed to be sold as a portion of the diagnostic time.
So have you put the old ESIM back on the truck and proven that it is in fact OK? If not understand that it may take a week or two to turn the light back on if it isn't. At $800, it's not a good one. It might be enough to handle DIY, but will actually fall well short of what a shop needs to assist in diagnostics as much as 90% of the time. Professional level tools run $4000 and up (aftermarket tools) and require updates every six months to a year that consume another $1000 a year on average. The factory tools that Chrysler uses cost $6000 for the DRBIII, $6500 for the StarScan, or StarMobile, $7000 for the WiTech and Chrysler even has another new tool coming out. Western Pa. is just as bad when it comes to the road salt destroying the cars. Time and again we see the perception that diagnosing the bad wire once it has been located was something that should have not taken any talent or effort at all. If that was really the case then you should have seen it when you replaced the ESIM. The reality is that it isn't usually that simple and that's why those things do get missed. It's highly likely this was assigned to a more senior technician for the re-check and if the shop didn't pay him/her for their time then you should get your money back. I used to be that technician who got to fix the come-backs with the promise that some gravy work would be sent my way to "make-up" the time.
