How do I keep my ignition module from overheating?
angellhogangellhog Member Posts: 1
edited June 2015 in Lincoln
The ignition module overheats and I cannot start the car
Answers
  • techmonkey1techmonkey1 Member Posts: 9
    edited June 2015
    make sure the connections are tight and clean and wiring is in good shape. Loose electrical connections can cause excessive heat.
