02 Tahoe dash warning lights
                    I have an 02 Tahoe, 115,000 mi. very good condition, recently the security light & battery  light flash off & on, the temp gauge and fuel gauge go up & down. Does anyone have a solution ?
Answers
I'd suggest 2 things and the first is the instrument cluster may not be making good
contact. If you remove the instrument cluster and look at the contacts that it punches
into you may find corrosion has developed with age.
Second is to put in a different battery unless the car was doing this BEFORE the battery
replacement 4 months ago. People have found different defects internally in batteries.
Can you switch out a battery from another vehicle that has positive and negative
posts located so the correct cable can reach to them when placed in the Tahoe?
Do you have a service manual by GM (Helm) for this truck? I'd suggest if you
do much work on it, you might enjoy having to help see how the dash cluster is
designed and removed. But I see huge pricing on that actual sets from Ebay ($249)
http://www.ebay.com/itm/2002-CHEVROLET-TAHOE-AVALANCHE-DENALI-ESCALADE-SERVICE-MANUAL-SHOP-REPAIR-/151699519460?hash=item2351fef7e4&vxp=mtr
You can buy them new from helminc.com maybe for not more than that
and you can buy the service DVD that covers all models and many years
for a higher price if you have more than one GM product.
My punt would be to check your local public library. They may have a subscription
to Alldata. Our county-wide system does but I can't use it from home like most
of the other databases using my library card number. I have to into the library
branch because they pay a license fee per computer for that Alldata access.
But I can print out for $.10 /page and the last time I could actually save
pages and pictures to a USB data stick from the machines they had then.
