Ready for First Service at 10,000 Miles - 2015 Ford F-150 Long-Term Road Test
After 10,000 miles in our long-term fleet, it's time for the 2015 Ford F-150 to go in for its first service.
You knew the max before first change would be 10k, and you knew 10k would come during the trip to Idaho...should have done it before you left.
Side note, my old '13 Focus ST called for a first change at almost the exact same mileage. Although it had a lot of highway miles it did see some driving in desert heat and the turbo was well utilized, an oil analysis showed the factory semi-synthetic wasn't quite at max service life so it appears the Ford system does leave some margin of error.
Actually if it is an algorithm based system it does know when you're towing and how many miles you towed. The truck's computer knows when a trailer wiring harness is connected and engaging tow/haul mode would also tell it you're towing or hauling heavy loads.
So while the controller knows when the engine is working harder, there are still other variables like dirty/dusty conditions that can push you into the severe/hard duty maintenance schedule. There may also be some added safety built into the recommendation that even though the oil life monitor should be able to account for higher loads the engine is seeing, the manufacturer still plays it safe and calls for accelerated change schedules.
