BCM issue?
rfb003rfb003 Member Posts: 1
edited July 2015 in Saturn
I have a 2003 Saturn Vue that will start and run then die after 2 seconds or so. I thought we needed to reset the security, but the Security light never comes on. I get both the service and the service with a wrench. I put it on a computer and we get the U2107 code. Can a weak battery be the culprit? I cleared the code and it started then as soon as I turn it off, the code is back and it starts then dies. I'm told that it needs a BCM, but the code indicates that the BCM cannot communicate with the ECM. Help?
    Sounds like it may be BCM related, could be BCM, could be wiring to BCM (Connection) , could be battery that has seen better days and proper current not getting to BCM. Of course could be something entirely different :)
