No dash/tail lights. 2000 Impala.
when automatic headlights come on it blows fuse to dash/taillights.if key in but in off postion when replacing fuse it snaps before its all the way in. replaced head light switch worked for a couple days then stopped again.had recall done on ignition after they replaced ignition is when my problems started.found out brothers impala same thing started after new ignition put in. please any n all helpadvice anything its driving me nuts find where this is a problem for alot but never no way of fixing it thanks everyone
Answers
Anyhow, before looking at the circuit diagrams, I'd suggest pulling the relay for the rear defroster. See if the problem goes away. No charge to just pull it--don't replace unless it fixes problem.
I don't understand why the ignition switch might cause the problem to show up.
Good luck and hope that works for you.
http://www.2carpros.com/questions/chevrolet-impala-2000-chevy-impala-dash-light-out-when-when-lights-auomatica
Might want to check with the folks at that forum as well. Good luck.
