ABS code C1233 R F Speed Sensor open or shorted with ABS and TRAC OFF lights
[Deleted User][Deleted User] Posts: 0
edited July 2015 in Buick
Have a CURRENT code of C1233 showing problems with the right front ABS sensor. Also have following history codes:
C1216
C1222
C1226
C1233
C1275
C1298
The ABS warning light and the TRAC OFF light are lit on the dash and pressing the TRACTION button on the console does nothing.
What is wrong and what do I do to fix it?
  • Was a broken wire near wheel speed sensor. Took a week to find ECBM connector pinouts and 2 hours to fix
    Thanks for reporting the fix you found.
