Just Got The Car.
scottzero7scottzero7 Member Posts: 3
edited August 2015 in Buick
Just got the car. Has an icon on dash that looks like a gear.
  • scottzero7scottzero7 Member Posts: 3
    ANYHELP HERE ?
    DRIVE IT OR NOT ?
    NEW HERE ON THIS SITE, SO I NEED ALL THE HELP I CAN GET.
  • cmhj2000cmhj2000 Member Posts: 381
    Ya you got a car. What do you want?
    All caps can be hard to read so lots of people skip over posts in caps.
    Did you get a manual?
    How To Find Your Car Owner's Manual Online
  • imidazol97imidazol97 Member Posts: 27,838
    Here's your manual in pdf form. Give it a couple minutes to download and then save
    it in a folder where you can find it again later when you want to look up something.
    http://www.vadengmpp.com/owners-manual/buick/1996-Buick-ParkAvenue.pdf
    Where on the dash is the gear? In the speedometer area?
    How large is the diameter? Is it a light or just a picture?
    Or are you looking at holes in the plastic trim about the
    driver's right knee that are little holes for air return for the
    temperature sensor on automatic temperature control
    models? It's about 2 inches in diameter with a pattern of
    holes about 1/8 inch diameter?
