A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Vehicle Break-In Period
Engine Oil - A slippery subject Part 2
Your host, Bruce
1. avoid full throttle starts/rapid acceleration
2. avoid hard braking.
No mention of varying speeds or anything.
I have put up 360 miles on my new civic - city+highway, and have only revved up at 4000 rpm accidentally for 3 minutes or so - else always stayed below 3000 rpm (generally 2500). I have not really varied speeds - done 80 mph for maybe 1 mile and 75 mph for a few miles, but stayed below 60 mph. All gear changes performed below 3000 rpm.
Do I have anything to worry about?
u take a sample of your used oil when u are doin an oil change. and u send it off to the lab.. the lab does a spectrial analysis on the oil, and they in turn send u a print out of parts per billion on what types of metal they found in your oil. and they also give u a how goes it on your engine they tell you if the levels of the particular metal they found is within normal limits, or if it is wearin excessively, and they can also tell you if your engine is getting the right fuel air ratio, and if u have something that is wearin too excessively they can tell u what is failing in your engine i.e. frount main bearing and so on..
I have found the kits at autozone, but they are too expensive for me, so call and check around, there may be someone local who will have a kit or they might do the testing in your town...
I found that at a local autoparts store the kit was 10 dollars and it took two weeks for the lab to send my results back to me......
Rob
www.blackstone-labs.com
But where is the junk from the the less-clean 10-40 is going (or not going) for the 10-30? I would think that if the oil has more junk at changing time, it has done a better job of cleaning.
Sunday - its about a 600 hundred mile round trip
with probably another 100 or so of sightseeing. My
MPV will have about 500 on it before we leave. My
question is: Should I change the oil before or
after our trip?
p.s. try not to overuse your cruise...:)
You could always drive some back roads on days one and two. That should give you some stop and go driving. While I don't know where you are going, I'm sure there are ways to go that don't involve exclusive interstate travel.
Just some thoughts...
TB
Bruce
I have a '00 BMW Z3. The recommendation from BMW is that the first oil change be at 15,000 miles. I originally thought they had one too many zeroes there, but upon closer inspection I discovered that that is exactly the right number. Apparently they suggest every 15,000 miles or two years. Seems more than insane to me...someone who almost religiously had the oil changed in my old car every three months (never put 3000 miles on in three months).
My brother, who also drives a BMW, recommended a change at 1200 miles and then again about every three to four thousand miles - always using the prescribed synthetic oil. This seems like it is wasting the synthetic oil (and seriously denting my wallet!)
Any suggestions?
I changed my oil at 2000 miles.
You will soon find out, there is no such thing as break-in oil.
At most, they use a 20 weight (I've heard this about VW's) But have yet to find that bottle marked. Break in oil.
Also, the long-blocks sold at Advanced Auto Parts come with Mobil 1. Now I don't think that is a special break-in oil either.
TB
I have yet to find any special oil or additive. It may be out there, but I've never seen it.
Just check any Chiltons or Haynes manual (they usually have an engine rebuild section) and they don't seem to call for any special oils.
Cheers,
TB
Some of the stories from Volkswagen are pretty insistent that a break-in oil is used in those vehicles but, even there, I haven't heard of anyone coming forward with real evidence regarding the use of break-in oil. However, tboner1965, we're still listening, aren't we?
My memory says one major OEM pretty much just wanted additional Q.C. documentation on a our GF-2/SJ Passinger Car Motor Oil.
And, yes, in general, highly special break-in oils are less common it seems. I would not change befor first severe service mileage on new car (usually 3K). The oil is likely still fine at that point, but I have seen on my cars at least, extra visible bits of metals in the first filter when torn down for observation (messy!). Just in case the filter blew out (very, very unlikely albeit) wanna get those bits outta my engine system early.
My question is, has anyone heard anything about how well this system works? As in, has any major damage been found by following the computers' suggestions? The free maintenance that comes with all new BMWs is based on this indicator, so unless you want to pay, you have to go with its suggestions. Also, I've heard of the early E46 3 series vehicles having problems with the stock oil filters over this extended period of time. BMW is aware of the problem and I'm fairly sure has fixed it by now since the information is fairly old, but does anyone know for sure?
So now I ignore the computer and stick to my time proven 4000 mile or so oil change interval. I've owned many cars past 100,000 miles with no engine problems.
Like the other post said: check with your dealer.
I've never seen 5W20 either.
Are they putting more risk on you the owner to squeek an additional 2/10th of a mpg?
Any advice would help.
