Vehicle Break-In Period
2456
  • bluemistbluemist Member Posts: 23
    I do vary the speed as much as possible (usually from 65-80 MPH), but going 45 MPH on the highways in Massachusetts during rush hour is a great way to get rear-ended.
    I'll try to do more short errand runs around town with the car, which will give a greater variance in speed.
  • zeddzedd Member Posts: 2
    Get this. New cars may be storing break in data that the manufacturer could use to void your warranty. I have heard Harley does it.
  • guitarzanguitarzan Member Posts: 875
    What? Do you need to break-in a Harley? They feel like you're driving around a chain-driven piece of furniture, even AFTER break-in.
    Guitarzan, yours must be vintage. Harleys have been belt driven for some time now. You should get a Honda, but watch your RPMs during break in.
  • rajamansinghrajamansingh Member Posts: 3
    I bough a Ford Explorer 99 2D, 4x4 SOHC auto.
    I already have 2000miles on it, averaging 135miles a day (mostly Highway driving).
    Is the break-in period over ? What do u feel about what I did so far regarding break-in period.I have feeling I screwed it up big time !
    Please offer some advice.
  • spokanespokane Member Posts: 514
    There's no distinct point at which the break-in is over. Generally, at 2000 miles, the break-in is pretty well accomplished but it only makes sense not to punish the engine with full-throttle driving for another 1000 miles or more.
    It is best to vary the engine speed somewhat during this period, but the key points for a long-life engine are avoidance of sustained full-throttle operation, keep proper oil in the crankcase, and avoid of overheating the engine.
    What have you done to cause you to feel that you have caused damage?
  • cwilkescwilkes Member Posts: 5
    I just picked up my silver ice X XE V6 w/7 miles on it. I am concerned about the break in period? Should I change the oil at 500 miles? Does Nissan use any sort of break in oil? A mechanic at the dealership said it was a good idea to change it but the salesman said that there was no need. Any comments would be great.
    Both those guys are correct, in a sense. You don't need to change after a few hundred miles, the owners book probably says ~5000 miles.
    However, as has been said by many contributors here, it does provide an extra measure of assured long and healthy engine life to change the oil early. I'd suggest 500-700 miles. Also the filter, of course. Subsequently, changes somewhat more often than the manufacturer suggests will be helpful. Choose a good brand (most are good) and use the viscosity prescribed by the manufacturer. May you have many miles of good motoring.
  • urchin34urchin34 Member Posts: 70
    I have the opposite problem of most. My communte to work is less than 4 miles round trip (yes, sometimes I even walk it) and the nearest freeway is about 15 miles away. In short, unless I go out of my way to do so, I can go a year without going over 45mph. Then on vacation, I will put on several thousand miles at freeway speeds. What do I need to do to adequately break in a new car (specifically Lexus or Toyota)?
    Obviously, I don't really live in Pasadena (wish I did). Many, many days over 100 degrees here. Maybe once or twice a year it gets as cold as 25 over night. Car garaged at night, out in open during the day. Does this all make any difference to break in?
  • khakiboykhakiboy Member Posts: 4
    I just bought a 2000 Neon ES and am wondering what the proper break-in should be. Should I keep it under a certain speed for so many miles? Should I avoid taking it on the highway and if so how long? This is my first brand new car and I want to try to keep it alive as long as possible. When I'm done with it the car goes to my mom so we'll probably run it until it dies. I never thought about changing the oil sooner the first time. But it does make sense. My owners manual suggests 3K miles for "extreme" driving (stop and go, etc) or 7500 miles for "normal" driving. When should I make the first oil change? Thanks for the advice!
  • jeekayjeekay Member Posts: 5
    The owner's manual of my new 99 Maxima says the first oil change is at 3,500 miles. Should I have my dealer's service department do it at 1000 anyway? Also, I've been careful to vary my speed during the first 1000 miles as recommended by the manual. The manual also says not to drive over 55 mph for the first 1000 miles. Could any damage really be done by taking it up to, say, 80 mph for a few seconds now and then during this period?
    If you've done it already, don't worry about it. However, the owners manual instructions should be followed if possible. They are the best authority for each particular vehicle.
    guitarzan
    Community leader/Vans conference
  • mlsulimlsuli Member Posts: 15
    I picked up my '99 Honda Accord EX V6 on Tuesday,
    August 17. As I was going through the owner's manual with my sales man, he did everything but sing, dance, and jump to the fact that they didn't want to see my car in the shop until I had reached the 7,500 "break in oil" recommended intrval. He told me that if I try to get the oil changed at the dealership they will refuse the car. It was absolutely critical that I keep the same oil in the car for 7,500 miles.
    March 1998. Dad bought a MB CLK320. My Honda story above is almost word for word what the MB dealer told my pops. Being that both my dad and I are 3,500-5,000 oil changers he brough his car back to MB to have the first oil change at 4750 miles. They refused the car - (unless there was something wrong with it; which there wasn't). They shoved him back in the car and told him to "go home".
    So those of you that have concerns here are three auto manufacturers (two in this posting, one from posting #64)
    1. Honda
    2. Mercedes Benz
    3. VW/Audi
    that tell you that you can go 7500 miles before you get your first oil change. Since the engineers did such a great job on engineering the '76 MB that saved my dad's life from an 8 car pile-up; I'll trust them to tell me when I should change my oil.
    BTW: Honda DOES recommend that you change your first "factory oil" at 3750 if you drive regularly on dirt roads, tow regularly, or sit long intervals in stop and go traffic.
  • jonathan75jonathan75 Member Posts: 10
    I am getting my new 2000 Corolla from a dealership 75 miles away! How do I drive it home? I can't go over 55 during the break in period and I only have the freeway. Plus I need to change my speed around all under 55! Do I just put my hazard lights on and pray that I don't get hit? The freeway is like the only way to go home! :(
  • chevy05chevy05 Member Posts: 5
    Does gas mileage tend to improve after the break-in period? I just bought a 99 Honda Civic, currently sitting at about 1500 miles on the OD and am on the low end of their gas mileage scale. I primarily drive what I would consider highway, with an occassional stop light. It seems that I am averaging 32 mpg with an Automatic running A/C 85% of the time? Is this good for a Civic. I just stepped up from a Geo Metro 5 speed No A/C which I was getting 42 mpg +/- . Maybe it is normal for the new Honda considering it is a heavier vehicle, automatic, A/c and a 4 cyl. and I am just used to driving the Geo with a 3 Cyl.
    I failed to mention this is a Honda Civic LX, if that matters. Most recently I got 28 mpg. That's not very good. I would expect that from a mid sized car. I am not hammering the gas peddal either. I am driving conservatively. Any ideas? Should I take it in and have the dealer check it out, although there probably isn't anything they can do.
  • retzer2retzer2 Member Posts: 4
    I recently bought a new Nissan Quest ... the manual and the dealer both recommended the same thing: for the first 1000 miles, no quick stops or quick starts, vary speed as much as possible especially on the open road, and don't take it over 65 mph at all.
    The owner's manual recommends the first oil change at 3000 miles. I specifically asked the dealer's "product specialist" -- I guess you could call him the go-to guy who fields your questions about whatever -- about break-in oil and he said Nissan doesn't use it. He also said the dealer will change the oil at 1000 miles for free.
    Elsewhere in these topics, I have seen recommendations for changing transaxle fluid at 1000 miles also. The rationale for these changes is the same: remove the fine metal bits that are bound to be suspended in the fluid. I am pretty much convinced about the 1000-mile engine oil change but am still on the fence as far as the transaxle change goes, and haven't gotten around to asking the "product specialist" about that one yet.
    I would do whatever the Nissan Customer Service or Dealer tells you (and have them document it too!). Follow that to a "T" and if anything goes wrong in the future you have the defense of following THEIR instructions.
    One more thing to remember - (in further support of posting #64) - filters, oil, and 'fluids' these days are engineered/designed so much better than what we had in the past. So I think that some of the mechanics knowledge of the past is virtually moot for today's cars.
    My last car - 1994 Nissan Altima - had its oil changed every 3500-5000 miles depending on driving conditions. Many times - even at or near 100k - the oil was maybe the color of Samual Adams beer hardly dirty at 5000 miles! So when automanufacturers say that their cars can go 7500 miles I don't doubt it....
    Follow your owner's manual to the type of driving you do and you will be safe. As mentioned above, the engineers of the car companies have spend some $$$$ on research - they, more than anybody on these postings - will know what the limits of their vehicles are designed for.
    Enjoy!
    Enjoy!
    Mlsuli et al, you can click on the post number, and it gives you the option to "scribble" (delete) your post, if you wish. This is handy for duplicate posts especially.
    Jonathan75, 75 miles isn't really too bad. Yes, going under 50 can be dangerous, and I wouldn't recommend it. Vary your speed every 10 minutes, from 50 to 58 or so (I do not advocate breaking the speed laws), and you'll be fine. The key is to not rev the motor too high. Don't do any full throttle accelerations, as the motor revs higher when you do. Take it easy, and try to do some gentle city driving for your next couple hundred miles. The car will be fine.
    Yes, some cars, like Mercedes and BMW have super-hard piston rings and cylinders that take several thousand miles to break in. Many Japanese cars have ceramic cylinder liners, and don't really need a break in. I wish the information for each model car was published, but I've never seen such information. So just follow the generally prescribed rules for your make of car, and by all means, don't worry about it. Cars are manufactured to high tolerances nowadays, so you don't have to be so precise about it.
    Stoli, thanks for that informative post!
    Chevy, in general, mileage will improve a little after you've driven the car a while. However, atmospheric conditions, road conditions, and driving habits play a part also. I had an Integra, and never got more than 32mpg, even when doing all freeway and taking it easy. Some Civic and Integra owners report much better mileage than that. As long as you're in the ballpark of the car's rating, don't worry about a few extra m's per gallon. Oh, yes, your Civic has much better power than the Geo does, for passing, etc. This is a major factor in the mileage it will get.
    guitarzan
    Community Leader/Vans Conference
    I found a road I can take with lower speed. I think it is 55 and not 70. I will change my speed from 40 up to 55 and back down. Thanks for your info!
    Speed really a factor in break-in? I know the merits of varying speed but the over 55 thing is dangerous?
    I've already had my Honda to 85mph. Both scenarios were the "I'm in the slow lane doing 85 and everyone else is flying by"!
    The V6 redlines at 6300 so for the first 500 miles I figure I'll keep it under 4000. Gradually I'll move upto 5000 then to 6000 (if needed).
    Is this paranoia or are there some benefits?
    Thanks all!
  • stolistoli Member Posts: 7
    The reasons for limiting speed during break-in have little to do with the engine. Drivetrain components need to seat properly and loosen up. For example, if the wheel bearings rotate at high speed early in their life, excessive heat will build, scoring the races and rollers. This applies to any of the bearings within the drivetrain (transmission, CV, differential). The same applies to gears. You won't see the negative results for awhile, but components may fail early. In the meantime, your drivetrain will make slightly more noise than one that was properly broken-in. But don't worry, I couldn't carry a conversation over the sound of the tranny in my '81 Celica, and the car just kept going.
    Well I guess my saving grace is that I've only been at the 85 mark about 20 miles out of the 500 I now have on the vehicle.
    Hey stoli does your post qualify as a "fire and brimstone" sermon? ;)
    I think I'm safe. However, I'll watch the speed for the next 500.
    Thanks for the feedback. Makes sense.
  • sunilbsunilb Member Posts: 407
    I currently have 600miles on my civic, and recently I noticed that the engine (at idle) is a little louder than when I first bought the car (at that time it was *dead* silent). Is this normal for a new car?
    It doesn't sound bad, just noticeable. Otherwise, the car drives great and I've been fluctuating the speed.
    Also, how have other Honda owners fared with their first oil-change at 3500 (or 7500) miles? (I also inquired at the dealership and they said to leave the original oil in there until at least 3500miles).
  • maxim5maxim5 Member Posts: 6
    I am going to pick up my new Acura TL3.2 (2000) in about a weak. Taking into account many posts here I will try to make more around city driving at the beginning but I can not avoid 250 miles weekly freeway round trip. The car has 5 speed auto and I think at the speed around 55Mh the RPM will be reasonably low even at the 4th gear. I am wondering if I should vary the gears between 4th and 5th during such kind of slow freeway driving to imitate "speed variation" for better engine break-in? Is it bad/good for transmission? Thanks a lot for any comments.
    Go to the book store and buy a book called "Drive it Forever." GREAT BOOK! It tells you how to break in a car! And make it last!
    Sunilb, everyone has a different opinion on the first oil change. I had an Integra and changed the oil at 500 miles. However, I sold it after 65k miles. Honda dealers are told by the factory to inform owners to keep the oil in, like you were told. Now knowing this, I think you cannot go wrong following the factory's instructions.
    guitarzan
  • alexkvualexkvu Member Posts: 2
    does anyone know if the shifting on the automatic is going to become more smooth over time, mine is a little harsh.
    Also noticed that it pulled a little to the right. Checked tires, all seem normal. Should I see the dealer to get re-aligned. How bad must it become before I take it in. I have 1200 miles on it an did not notice until I was doing some longer freway miles and let go of the wheel with no acceleration. I dont want a problem to get away.
    Thanks a bunch,
    alex
  • csfeircsfeir Member Posts: 1
    Hi to all,
    I read most of your posts and thanks for the info. It seems following the manufacturer recommendation is the thing to do. In my owner manual they recommend to change the oil at 5,000 miles. They don't speak of breaking in etc. What would you do? your advice is very appreciated.
  • jefe5jefe5 Member Posts: 14
    No full throttle starts and use gentle braking. Slowly increase rpm. After 1000 miles begin getting a little more aggressive and a little higher on the rpm. save the full throttle starts for after 1500 but don't [non-permissible content removed] it forever. Avoid one speed and rpm for long periods of time during breakin. Breakin is not nearly as crucial as it was 20 or 30 years ago.
  • hundthundt Member Posts: 1
    I am new to the list and have a question and a comment regarding break in. Years ago when I test drove a car a Demo (used personally by the salesmen) was used specifically for that purpose. For the last few years, however, it seems that new cars are used for that purpose. Especially hot cars get thrashed around by the salesman demoing the car and then by the prospect to impress and to see what it will do respectively. After several such demos the car is then sold as a new car with 200+ hard, high revving, hard breaking miles on the odometer to then receive it's break in procedure from the proud new owner. My last two cars purchased were ordered made from the factory for this reason.
    Am I just old fashioned in my reasoning here? I know break in is not as critical as it was 20 or 30 yrs ago but I do Not believe claims that no break in is required. Mass produced pistons and cylinders simply cannot be built w/o any imperfections whatsoever on their contact surfaces. The same rational applies to new brake drums or disks.
    Any comments agreeing or non are appreciated,
    DH
  • gyehgyeh Member Posts: 1
    We just bought a new Infinit QX4 2 weeks ago. It's got 130 miles on it now. We plan on driving it from Boston to Washington DC next week- usually a 8-9 hr drive (about 500 mi). I hadn't thought about the break-in period until now... What should I do? Is this a really bad idea for the car? Suggestions? Perhaps frequent stops?
    Good points, hundt. Indeed, this is one of several good reasons for ordering a new car rather than purchasing from dealer inventory.
    I expect that conservative cars suffer less abuse from prospective buyers than do the performance models. However, a few of the salesmen seem to delight in abusing a new Mercury Marquis just as much as a sporty Cougar.
    We should also be careful in purchasing a car that is "swapped with another dealer 100 miles away." Some of the drivers employed to move cars between dealers are quite careful but I think we have all observed a few who are determined to drive as fast as possible.
    As to the odometer readings, there is a small consolation. It's my impression that today's dealers are not likely to tamper with the odometer reading.
  • wordvoyagewordvoyage Member Posts: 9
    I have just read a great book,that someone else recommended in this form, about proper break in,"Drive it Forever" by:Bob Sikorsky.To summarize the book recommended some things I had heard years ago and believe make for some common sense:No full jack rabbit starts and no high revs of the engine in low gears.Of course vary the speed and even on occasion press the gas gradually all the way to the floor from lets say forty,fifty MPH,after getting to the speed limit of 65 or so,gradually again let off the gas back to the beginning speed.(I think many people are not aware of this)It's something I recall hearing as I said years ago and I have never had an engine related problem with my cars.This helps to set the rings in the cylinders the entire lenght of bore and build better compression in the engine.Also while cruising at any speed on occasion take you foot off the gas the allow oil to lub the top of the cylinders. also mentioned, one of the most important things to consider is the initial cold start up in any car(where most of the wear occurs) especially,the new car:Don't let it idle long.. count to five or so and start to drive at a slow gradual speed till engine warms up Also,after any substained long run,to let the car idle for a minute or two.This helps to discipate any heat build up in the engine.I have a new Beetle GLX Turbo and the car is very fast and having a hard time holding it back.I have tried to do most of the break in milage on the highway and will admit the first hundred miles, using the above procedure, have gotten the car up to 80 MPH,and it's just getting started!!However, right away letting off the gas slowly down to the speed limit.This was somewhat faster then the book recommends,but was crusing in fifth gear and RPM were still below 4000. hopefully,this will be ok.
    I agree that the gear meshing break-in is also important and also to follow the manufacture's recommendations,but they do not say much about the break-in process,except to vary speed.I do wish they would do a some more research,as not to leave the new owner in the dark.In my last post regarding the book,"Drive it Forever"I forgot to mention,he also comments the short local drive/trip is one of the worse things to do, not only for a new vehicle,but any as well.The distance needs to be long enough to get the oil/engine up to operating temperature.
  • mthikermthiker Member Posts: 14
    That should of read "at #75".
    Unknow to me I lost #88. I'll reentre here.
    Stoli at #75 is right. I work in an aerospace company and asked some of the engineers about gearing and bearing break-in. They agree the engine will do find but the whole drivetrain needs TLC. The gears and bearings need to meshes and mate with each other, that is way the 600 mile and 1000 mile break-in period. If the RPMs are too high too soon they may over heat and fail early thus have a shorter operating life. I just bought a Y2K Jetta diesel with a 100K-mile/ 10-year warrant so I will fellow the manufacture's plan.
    PS. Almost 400 mile and still over a quarter tank of fuel to go, Love it.
  • pat455pat455 Member Posts: 603
    Did you perhaps scribble #88 by mistake? If you clicked on the highlighted link to the post number "Hide" or "scribble" are then choices for you, clicking "scribble" would have deleted the post. (You can only do this if you are the poster.)
    That response was here twenty-four hours ago, I saw it....
    Pat
  • sosterhubersosterhuber Member Posts: 5
    Similar experience. Outright REFUSAL by the dealer to change the oil in my '99 EX at 1,000 miles...told me that it was imperative to leave the oil in for 3,750. An inquiry to Honda awaits a reply....we'll see. I trust these guys at this dealership, (really), they routinely go to bat with Honda for warranty work outside of the expiration period, provided that the car has had all the required maintenance performed. What about just changing the FILTER at 1,000 miles??? Any ideas/comments???
  • vac23vac23 Member Posts: 118
    There should be no harm in changing the 1st oil change at 1k. Even if there is "break in" oil in the accord the only difference between that & regular oil is that there's no detergent in "break in" oil
  • thetexanthetexan Member Posts: 5
    Hello all,
    I just purchased a new 2000 VW Jetta VR6. I received the car with 7 miles on it. I asked the dealer about break in oil and change interval and he said I should definitely leave the original oil in for at least 1000 miles. This seems to be good advice. He said they do indeed use a "break in" oil from Castrol. He also said not to take the car above 85 for the first 500 miles and also not to red line it until then. I haven't. I do know that I will change it at 1000. He said to use Castrol GTX10w/40...leave it in for at least another 2000 miles then I could go synthetic. This will allow all surfaces to mate and the rings to seat in etc.
    One thing I do know is that most (if not all) modern engines are internally "balanced" at the factory. This means that even though the parts like pistons and rods are mass produced, they are all weighed before being used for assembly. If you have 6 piston rods, you weigh them each in succession, then take the lightest one and use it as a standard for the group. So for example, if the lightest rod weighs 2.1 lbs then the rest are shaved down to 2.1 as well. That way the reciprical masses of all components in the engine are even. That is why modern engines are so reliable.
    Of course advances in cylinder head design and internal balance shafts have made a huge contribution as well. I know for a fact that the German companies like Mercedes Benz, Porsche
    and Audi/VW have been doing this for years which is why they are renouned for their engine life expectancy. As far as I know all manufactures with the exception of a couple I wont mention do this today. My two cents.
  • roadpilot3roadpilot3 Member Posts: 17
    Please mention the manufactures that that don't do the the balancing. Can't leave us hanging like that.
  • mnrep2mnrep2 Member Posts: 200
    Will be picking up a 00 VW Passat GLX @ Xmas:) But have to drive it home after 1 week visiting the family. The car will have 250 miles, hopefully b4 hitting the Expressway back to MN. Any suggestions appreciated.
    P S Will be stopping for an overnight about halfway back.
  • tauberjtauberj Member Posts: 61
    mnrep2, when driving your 700 mile trip, do not drive at any constant speed for too long. Vary your speed between 45 or 50 m.p.h. and 70 m.p.h. This way, your piston rings will seat properly. Other than that, do not let the engine rev too high (under 3000 r.p.m.). Good luck, and most of all, enjoy your drive!
    Honda's website does detail a breakin oil. The difference is not detergent as someone suggested. The breakin oil has friction modifiers, which allow certain wear to occur.
    VW also does this, I know for sure. They have particularly hard rings/cylinders and need to break in.
    Guitarzan
  • 5th_corps5th_corps Member Posts: 11
    When was this book published? The "Drive it Forever." I would like to buy a copy. I just got through 12 years on an 88 Olds Cutlass - But I bought it 7 years old with 35K on it.
    Does the book say how long one should be at the operating temperature? I just bought a 200 Cavalier - and it gets to operating temperature - a shy bit below 195 in a matter of 5 minutes on the road.
    Does it also talk about doing oil changes and filters? I am not goign to change my own oil, and install Mobile1 Filters.
    I should say that the 2000 Cavalier gets to the temperature in less than 5 minutes even driving it gently - I live right on a 45 mph road which drops to 25 after a mile or so - but I still drive it gently.
    That was interesting about the sustained trips - to let the car idle a bit. Does it say how long? It almost seems as if the Cavalier cooling system, and I am not sure - is designed to keep the temperature at about 190. No matter how fast or slow I drive (my commute is a combo of 45, 25, 65 mph roads, sustained on 65 mph longer)- once it gets to 190 - the gauge will not move, ever during idles at lights or waiting for trains - until I decide to turn the engine off for the long ones.
    I believe the book was first published in the 70's and latest in 1997.I got it at Border's Books(was in stock) but if not I'm sure can be ordered from any book store.As you know the worst thing on a engine,new or old is the cold start and to reduce wear to get the engine up to operating temp as ASAP.Book says all gasolines are not refined the same and some will get the engine up to temp faster then others.(Believe this is called flash point)No brands were mentioned.Too bad the gas company's don't put this info on pump.My Beetle has a blue cold light which goes out when up to operating temp,generally in 1 mile or so.Of course during this period driving is very gentle and even awhile after the light goes out.Book does not say how long to keep at operating temp,but sure you are ok..As far as the idle to cool hot engine after a long highway trip or hard driving around a minute or two would be ok.With a Turbo there is more concerned for it produces higher temps then a regular engine.Oil and filters are mentioned including the use of sythetics.One thing stressed is use the manufacturer's recommended oil change interval under stress conditions as short trips(a killer for new or old engines)More driving then realized is done less then 10 miles and engine doesn't have the time to get oil and temp up.The two things in book that struck me the most was to vary speed and as I heard years ago,on occasion when at speed of 40-45 on highway,put the petal to floor,get up to speed limit then slowly ease back off the gas back to beginning speed.And on occasion when cruising on the highway let foot off gas.Everyone has an opinion and breaking in a new car is no different however, "Drive it forever" will rid some of the confusion.Breaking in a new engine is mostly common sense and maybe as a new relatioship,Don't baby her,but treat her with respect.
