Monterey Car Week - Two Visits to the Yugo Doctor - 1989 Yugo GVL Long-Term Road Test
Edmunds.com
Our 1989 Yugo GVL had to drive from Los Angeles to Monterey under its own power, and there were a few issues to iron out. So we visited an old Fiat mechanic. Twice.
If the car came out of the fist visit running like champ then it's justified. But it actually ran worse after the first trip, and when you end up spending $566 for a brake and carb adjust, additional filter and dash light contact repair over two visits it becomes another example of why people generally don't like or trust people who work on their cars.
They removed the air cleaner for a visual check and found that the "Center Venturi has fuel dripping out of it". That statement alone says a lot about what the vehicles present condition was while it was being examined. The first possibility for fuel dripping from a venturi is that the float level is too high and incorrect, but the more common cause is an engine that is unable to idle on just the carb's idle circuit. So that means to me that someone has turned the idle screw up to the point that fuel is starting to flow from the primary circuit just to try and keep the engine idling. What they have succeeded in doing is making a moving target of the diagnostics and repairs by adding an additional problem on top of some basic failure. (failures) I believe it says they spent $287 and were clearly told about additional repairs that were discovered but not approved at that time, and it wasn't running well enough yet for them to go on their trip and they finally approved the rest of the work. Now during the rest of the work the description of the events works to reveal that once previously discovered issues were remedied, another picture became clear. On top of all of the other problems there was/is still a fuel quality issue which the Band-Aid of a second filter might help but is very unlikely to solve IMO.
This story isn't over, there is quite likely going to be a lot more to this. Having personally repaired a lot of those Holley-Weber Model 740 carbs, and having dealt with the emissions controls on cars of that era the shop is in for a steep learning curve before they actually get this to run "right". Each symptom will need to be first experienced by a driver, and then investigated and repaired by a technician and then they will then have to wait and see if anything else shows up. The idea that anyone could solve a performance issue on these without a drawn out, and possibly painful process just goes to show how little people really know about what the job demands. The idea that they should be discounting any of this, when they probably have lost a ton of productive time to it already couldn't be more wrong and trying to force that perception has worked to make it less likely for consumers to find talented technicians. This car presents as a once in a career experience for them and that's why they didn't find someone who could do it all in one shot. The biggest thing that the article gets wrong its the idea that their racing experience makes them more qualified to service this car. It does explain why they appeared to have an undisciplined approach to the diagnostics when they were playing musical plugs and wires etc.
Not surprising really. I get a sludge problem after sitting 10 hours at work.
For those who haven't read Josh's R129 SL500 blog, you can at 500benz.com!
