Why does the starter keep going out?
We have replaced he starter on my 2004 Kia Sedona three times in the last 18 months; the last time was a week ago. Now today I could smell a burning smell--kind of like plastic burning. It lasted for about a minute, then was gone. I looked under the hood and couldn't see smoke or determine where the burning smell was coming from. The engine light never came on. I'm afraid of being stranded again. Any suggestions?
Answers
Why did you replace the starter three times? Once was enough.
The problem is your battery cables. The connections are poor, damaged and/or loose.
I would start with the starter relay circuit. You will find a bank of relays under the hood. There should be a map either stamped into the plastic cover or printed on the inside of the cover. Locate the "Start" relay, first upon inspection; is it hot, does it appear to have been hot, warped looking, smelling bad, or just damaged? There is also a "Starter" fuse in the fuse block, and an "Ign2" fuse that are part of that circuit, check them all. Back at the relay: Don't ground out that relay, one terminal on it is connected to the E.C.U. and we certainly don't want to fry that, (Very Expensive, and then nothing works). Terminals 85 and 86 of that relay are feed and ground, use a multi meter set to the lowest DC voltage above 12 volts and check only terminals 85 and 86. Check them, both with the key in the on position, and with someone bumping the start position with the key. If there is voltage to that side of the circuit before bumping the starter, then there is a short That smell you smelled is almost always a dead give-away of a shorted circuit, or a circuit that has become a feed-back loop. I am including a simplified circuit diagram that I found online for your starter circuit, hope it helps and good luck.
Oh, the diagram is in .png format, you can copy it to your desktop and blow it up a bit to see better.
And once you find the short or the source of that smell, direct your mechanic to that area to test further with the proper diagnostic equipment.
