Do I have limp home mode?
I have a 2004 Chevy trailblazer LS 170k miles .
I recently had a bad transmission leak. Turns out I have some pretty bad rust underneath and it deteriorated my Trans lines. As soon as I noticed the leak I took it to the shop. Mechanic fixed the leak and told me I'm all set. He said the car is still shifting pretty weird because the new fluid needs to run through everything. He told me to drive it for a while and it will basically fix itself. Well, after driving I noticed I can not get out of second gear. It just revs really loud and runs really hot. And I'm afraid to over heat so I don't let it do that. I don't know anything about cars so I did a little research and found limp mode. It's sounds pretty much exactly what's going on with my car. My questions are:
Can a Transmission leak cause limp mode?
How do you fix it?
How much do you think it will cost?
Is that even what I have?
I bought the cat used 1 year ago and have kept up with all the maintenance on it.
Please help! And thank you in advance for all the input.
How do you fix it?
Answers
as for the limp mode, yes a malfunctioning transmission could cause it for certain transmissions but maybe not yours, and as far as i know, it's not usually the transmission which causes ECM to enable limp-home mode. the stuck-in-second-gear may or may not be limp-home mode.
regardless of any of that, the mechanic's initial story to you sounds like top-notch horse excrement.
consider to give mechanic a chance to fix it properly for zero dollars cost to you.
there may be additional repairs pending and/or he may be trying to fleece you. opinion of a second/trusted mechanic may be helpful either to complete repairs or determine what the initial mechanic was up to.
To the O.P.
This probably does need to be looked at by a technician, and its very likely that the transmission having been run low on fluid may have resulted in internal damage. With an older transmission a lot of wear would be normal and sometimes they just don't tolerate any issues and quickly fail if something goes wrong like this leak. It happens, its normal, and it isn't anyone's fault. Just be glad that you have someone who can handle this for you because when treated like that last post suggested its a wonder anyone ever bothers to learn how. Its most likely that while the shop you used can handle fixing the leak, internal transmission repairs might be beyond them.
" It never did that before you workied on it!" Ever hear that Cardoc?
