TPMS Gremlins Got Us Good - 2014 Mini Cooper Hardtop Long-Term Road Test
Edmunds.com
The 2014 Mini Cooper TPMS system develops a strange error. Edmunds investigates and tries to set the system right.
Jonathon, there is a very likely explanation to this situation. Do you have a certified gage? Has the gage you are using been tested for accuracy? You have four TPMS sensors most likely made by Beru that are in close agreement and a gage that is some six psi higher. You need to try a certified gage and not one that scales to 160psi.
One time last winter, on a very cold day, my TPMS warned of four equally low pressures. That only ever happened one time, so far.
With these clues to its functioning, perhaps someone can better explain what's happened here?
Can't say I've noticed a pyrometer at Harbor Freight, but I haven't looked.
As far as the TPMS system alerting about low tire pressures on a very cold morning, that is exactly what the system it is supposed to be able to do, it's NOT just to alert the driver if the car is having a tire go flat. The systems are designed to alert a driver if the tires are significantly over or under inflated. A system where the specification is 30psi should turn the lamp on if the tire pressure falls below 23psi, or rises above 38psi. Shops can run into an issue when the vehicle is inside the heated shop all day when it is being serviced if the tires are set to the placard and then the car sits outside the following night. If the temperature swing is great enough, the TPMS light will come on due to the natural pressure change that will occur as described by Boyles gas law.
https://en.wikipedia.org/wiki/Boyle's_law
I built one of these in the backyard to facilitate the process.
