No crank, no start. 2009 Toyota Camry
I have had no problems with my Camry until one day it didn't crank or start. I first thought either battery or starter. Well the battery tested at 100%, alternator
Best Answer
texases
Member Posts: 11,190
All connections clean and tight? If so, the starter would be next, Toyota starters can have their solenoid contacts wear, resulting in a no start. Other options are the ignition switch and the neutral safety switch (have you tried jigging the shifter? tried starting it in neutral?).5
Answers
