Squeal from serpentine belt or bearing?
I recently (last Friday) replaced the upper intake manifold and the lower intake manifold gasket on a 2004 Buick LeSabre with 167,000 miles. I was helping out a friend who is on a limited budget. The repairs went well, no problems there.
Afterwards, checking everything out, I detected a squealing / chirping from the serpentine belt, so I replaced that with a new Gates belt. I cleaned every pulley, and made sure every one was turning freely (with the exception of the crank, of course).
Now I have a different sound. I have not heard it sitting still, but on the road, when I let off the gas pedal, as the RPMs drop to about 1500 I hear a momentary squeal from under the hood. Only lasts approximately 2 or 3 seconds. Does not happen when accelerating, only when I let off the gas. Can't seem to reproduce the noise when sitting in the driveway, revving the engine. This happens only on the road, only when decelerating. With or without the A/C engaged. The sound is not very loud, and is somewhat low pitched (for a "squeal", that is).
When I was removing the intake manifold, I did remove / loosen one of the braces for the alternator. But it seemed to go back together without affecting the position / alignment of the alternator pulley / serpentine belt. This is by visual inspection only.
Okay, if I may, a second problem. When test driving the car, I observed a "clunk". I first noticed this when sitting at a stop sign, and releasing the brake to take off. My first thought was that the brakes were sticking, and releasing with a “jerk”. Later, trying to diagnose the problem, rolling along at 5 mph, car in neutral, touch the brake and release, the car jerks and clunks. Thoughts?
You might have a noise in the transmission that you can evoke by turning the wheel. Don't know if that's fixable or worth it.
Might be missing spring metal spacers on brake pads are missing and letting the pads move. I'd suggest a second set of ears to stand outside the car while someone drives the car and uses the brakes as you describe to get a better sense of the noise. Check the bearings on the struts. Hand on spring while someone turns the wheel with the engine running while sitting on soft surface like grass or gr
