Are you (or someone in your family) a first-time car buyer who is struggling to find an affordable used vehicle? A reporter would like to speak with you; please reach out to [email protected] by 1/21 for more details.
There Should Be a Door Grab Here, Part II - 2014 BMW i3 Long-Term Road Test
Edmunds.comEdmunds.com Member, Administrator, Moderator Posts: 10,184
edited October 2015 in BMW
imageThere Should Be a Door Grab Here, Part II - 2014 BMW i3 Long-Term Road Test
Every time I get in our long-term 2014 BMW i3, I'm reminded of a poor design choice that was made on the door panel. Turns out, it's not our only long-termer with this problem.
  • DebunkerDebunker Member Posts: 49
    I don't care how well the damned car handles or accelerates if I also have to live with something so stupid as a door with no simple means of closing it.
  • vvkvvk Member Posts: 196
    It is not bad, you just have to get used to it.
    I have always preferred door handles that you can grab without twisting your arm. Like the one Riswick criticizes in the 2-series.
  • markinnaples_markinnaples_ Member Posts: 251
    Just put a handle in the middle or more towards the rear of the door and call it a day. Even just an indention in the arm rest that you can use as a handle for closing the door works better than no handle or one towards the front. This is a failure of interior engineering and they should have determined that this door handle configuration was inadequate through normal use testing, IMHO.
  • bnovidabnovida Member Posts: 12
    Pull on on the door cubby instead.
  • uncanny_manuncanny_man Member Posts: 11
    What a hideous looking door! I've only ever seen that fuzzy plastic used on unfinished surfaces of cheap durable items, and that juxtaposition of angles makes it look like something went horribly wrong on assembly.
    edited October 2015
    Did an extended test drive of the i3 over the weekend again. The maximum miles I can get out of the electric charge using comfort mode is about 65 miles. Driving from LB to Alta Dena and back, we ran out of EV miles and the range extender kicked in. From the inside it sounded like a distant lawn mower. When we rolled down the windows, I can definitely hear loud lawn mower sound. At stop lights when the extender is running drivers from other cars where looking at us like WTH is that noise? Also we had to top off the 2 liter gas tank so we can make it home. It was ridiculously small.
  • stillageekstillageek Member Posts: 114
    I've had an I3 REX (Range Extender) for over a year. I've never once had a vehicle or person give me an odd look when the range extender was running. You must have extremely sensitive ears. The gas tank is 2 gallons, not 2 liters. The car isn't meant to drive cross country. I've used 10 gallons of gas in 12,000 miles. I've had max 72 miles on battery here in Texas. The majority of the 72 miles was on the highway at 60-70 MPH.
