Factory Installed fog lights
Is the GMC SIERRA 1500 base model prewired for fog lights ? If not, does anyone know the P/N for the wiring harness required.
Best Answer
93tracker5spd
Member Posts: 194
Hello! Is the vehicle wired for fog lights? Yes and no, what I mean is the main harness and fuse block is prewired for them, the harness from the fuse block to the front bumper is not present. However, there is a kit that contains the factory replacement switch, harness and lights. The dash indicator light is already pre-installed in the vehicle. I found a full tutorial which includes the kit number and very down to earth instructions. I am posting the web address below. Check it out, might interest you. Good luck.
http://www.gm-trucks.com/forums/topic/147854-oem-fog-light-install-2012-sierra/5
Answers
