Cleaning the Dirty Mopar Air Filter - 2007 Dodge Charger SRT8 Long-Term Road Test
The air filter in our 2007 Dodge Charger SRT8 looked dirty and it was time to clean it. But how?
some people less frugal then i buy an extra filter so that their car isn't out of service for a day while the filter is drying.
You might also get the right kind of spray cleaner for the MAF sensor wire and clean that - it might have some oil on it.
You don't have a scan tool that can display the engine load data pid? The engine load data pid is calculated from engine rpm and the MAF or MAP input. By monitoring that data pid and the RPM under a hard acceleration you can see how much air the engine is pumping against what the engineers predicted that the engine should be able to pump. There is a second way for MAF sensor systems and that is by using a VE calculator. This takes the engine rpm, MAF reported airflow in grams per second, ambient temperature, and the engine displacement and compares the MAF reading to the theoretical efficiency of the engine.
Here is one example. https://www.otctools.com/ve
Here is another. http://www.lindertech.com/downloads.htm
