Check Engine light
1121315171834
  • fleetwoodsimcafleetwoodsimca Member Posts: 1,518
    Don't talk about it. It is magic. You are winning. Cut and run! >;o]
  • kennedy13kennedy13 Member Posts: 1
    I have a 95 toyota tercel and the engine light has come on and off repeatedly. The first time this happened, I immediately went to have an engine diagnotis test done. They advised that it was the O2 sensor not the engine having a problem. Now, months later, the light goes on and off by itself, sometimes staying for a two to three days. Is this a defect in Toyotas or is there really a problem that I should be concerned about?
  • ranger96ranger96 Member Posts: 16
    I just bought a used 1996 Ford Ranger xlt 2.3L. When i bought it the check engine light was on and still is after one month. Is there anyway to turn off the light and fix it my self? And if the light is on will it make the engine run rough and not have that much power?
  • swschradswschrad Member Posts: 2,171
    if the MIL = check engine = $$$ light is on, it means there is a fault code being held in the engine control computer. generally the lights stays on until the condition is corrected, and if it's a significant one, a mechanic resets the computer.
    so you need somebody with a scan tool to pull the codes, evaluate them, perhaps diddle something else to see what it does and where that takes him on the diagnostic step chart for the faults in that section of the car... until they get to, "east platinum framistan is farbled, replace."
    once the service is complete, the tech needs to reset the computer with the scan tool. then and only then is the $$$ light out to stay.
    that's the process. pick one and go.
  • jasonsilbjasonsilb Member Posts: 11
    Well here we go again. The good news (maybe) is that the check engine light remains out/unlit. The bad news is the vehicle just died on me for no reason it seems. I was simply driving down the road, slowed to make a turn, and all of a sudden no more power steering! Put it in Nuetral and started right back up and hasn't burped again. But, this is the 5th or 6th time the car has died for no apparent reason. I appreciate any & all replies that I have recieved on this topic, but now I am at a loss. Obviously there is a fuel problem. But nobody can seem to find it on a diagnostic. I am going to take her in one more time and see what may show up...I will repost at that time and hopefully have something that will indicate a dif. road to take or I will be visiting my local Car Max.
    Thanks again to all who have taken the time to reply.
    how much gas was in the tank when it died?
    reason I ask it is that the baffles in the explorer tank allow fuel slosh to uncover the pickup on left turns with 1/3 of a tank or less, and the way you fix it is to drive on the top half of the tank.
    you may have a similar issue
  • craniumcranium Member Posts: 40
    Ok.. for those of you who do not know, I have a 1998 VW Jetta 2.0 liter....I posted a thread a month ago concerning my engine light comoing on. "Fuel Filter?"
    So the story goes: I was on my way to work, car was running fine.. then mis-fires and stalls... I took it into the dealer.. and yada, yada, yada.. turns outit needs $300 for the plugs, wires, rotor, and cap.. plus another $700 for misc things that they claimed I needed..
    I drove it home, (no problems there or back), and I replaced cap, rotor, plugs, wires, and for good measure, air, and fuel filter. It runs like a top!!!.. I love this car.. (this was about 4 weeks ago)
    Now, I put it in the garage for 2 weeks, while I drove my winter car. (been driving it to make sure all the bugs are out before winter). Anyway, This morning, I was in a hurry, and wanted to take the VW, I started it up, got to the end of the driveway, and it mis-fired and stalled again... after re-starting, It runs great. but the check engine light is on now. How do I turn this off?
    Last time, when I took it to the dealer, they told me the problem, but it wouldnt turn off till I replaced the above. How do I turn it off without replacing all that again?
    Please help.
    You start by having the diagnostic trouble codes retrieved from the engine computer and posting them so we know what system to look at.
    Contaminated gasoline? Water in the gas could cause some of these symptoms. Indeed, back to the codes to sort it out properly.
    on the way home from work. Thanks for the help anyway. I was posting here, because I didn't want to take it to the dealership, and pay $85 to have them just plug it in. I was hoping I could save the $85 by talking to you.
    Thanks for all the help though!
    Well the LIGHT is back on as of this morning. I new it would show up again.
    The tank was closer to 3/4 full. I appreciate the idea though. Well it's back to the shop I guess. Maybe there will be a code this time that points somewhere. Will post more as soon as I know more. This has got to have a happy ending at some point.
  • rayt2rayt2 Member Posts: 1,208
    You live in Buffalo so there must be a Auto Zone nearby, they will do a code scan for FREE so you at least have that to go by. They will also try to sell you things to fix what they are reading. I would hold off on that till sure of problem. Get the codes and post for those who know to help you out here.
    Ray T.
    I should have taken it to them last time, but I wasn't aware they could check it. I'll definitely go there next time (it will save me $85) The light is now off, and it's driving fine, Thanks for the help!
    Auto Zone also sells scanners for $29.95 per various brand. The kicker for these OBDII toys is that they are for nothing newer than 1995, apparently.
  • 0patience0patience Member Posts: 1,712
    fleet,
    Those are for OBD1 and are nothing more than a jumper with an LED light. There are very few of the OBD1 vehicles that we do not provide info for without a tool.
    Most of these tools are a waste of money. A few of them, such as the AutoXray scan tool do more than jumper the DLC. The AutoXray will do freezeframes and monitor sensors.
    Then there are a few others that do the same for OBD1.
    OBD2 is a different story. There are several protocals, regardless of what the govt. pushed for.
    We have one page dedicated to scanners and programs for OBD2 and it grows continuously. Different companies come out with scanners and scan programs on a continuous basis.
    All the sophisticated electronic testing is plainly out of my league, but I confess I am quite interested in the topic. Thanks for the added info on those Azone meters. (:o]
  • warrenulwarrenul Member Posts: 50
    Yesterday morning the Service Engine Soon lit up on my 2K 5 Speed Max. I just filled the tank the night before this had happened and I think that it is related somehow. I did noticed that it lit up during heavy stop and go traffic and I wondered if the erratic on-off on the gas and clutch might have registered a rich/lean erratic mixture just for a short duration.
    While I am not saying I don't trust the SES light, I want a simple way to extinguish the light to see if registers again. I want to change the brand of gas and tighten the cap until it clicks three times and fully seats. Then if it lights up again, then the problem lies elsewhere and a trip to a professional is in order. Problem is if its a simple fix there's no way for a saturday mechanic to know if he fixed the problem or not without having a scantool. Not all of us want to go back to the dealer who will inevitably try selling you hundreds of dollars worth of "preventive maintenence" in addition to the fee for dumping codes or to reset the SES light. And who wants to be without a car or have to take a day off from work just to bring it in for uneeded service. This is where I believe that some dealers can take advantage of this system.
    Now I want to restate that I said reset the SES light and not to erase any previously set codes on the ECU. While I intend to disconnect the battery to see if the gas/cap/traffic was the reason for the abnormality, I really wanted to avoid doing this because I didn't want to erase the radio presets and homelink controls.
    I am not advocating that the SES does not perform a necessary and useful function. I just wish that a novice mechanic has a way to make simple reasonable repairs without feeling helpless being at the mercy of the Service Manager.
    I will start shopping for a scanner as you have described on this board. I have read all the posts and have learned a lot from this discussion. Thanks to all who participates and to those who gives assistance to who needs it.
    just for the hell of it, push a button and the codes scroll by. it would cost them $20 to implement, mostly for a 10 or so character line display. we are not all stupid "like a rock" out here.
  • opera_house_wkopera_house_wk Member Posts: 326
    For their free code service. Yesterday was the second time I have used it. First time was for a tank evaporative leak that was a stuck solenoid. Now it was for engine misfire cyl #2 & #4. Well, #2 was ok and #4 had an odd brown coating on the electrode that was shorting it out. A new plug temporarily fixed it. Since this plug had only 8K on it, there is definitely a problem with a gasket or something. I've been told the intake is a problem with this 97 Explorer OHV. That's a different issue. Just want to say these folks have always been quick and friendly. It is allowing me to bide my time till the deluxe do everything scanner is only $50.
    fleet,
    The prices on scan tools is slowly dropping in price. They will always be a little expensive, but there are alot of alternatives out there. there are tons of PC based programs and interfaces.
    Some of the programs are free and there are interfaces available for around $75.
    warrenul,
    There is no way to "reset" the light. The light comes on when it detects a problem and goes out after a set number of restarts, when it no longer detects the problem or on some instances it will go out when the problem is no longer detected. If the problem is gone, the light will go out. If the problem is still there, the light will still be on.
    Novice mechanic, DIYer or professional mechanic, a scanner is a required tool anymore. Like it or not.
    On the subject of scantools. There are tons of them out there. educate yourself on what is available, then decide what you want it to do.
    I like the Auterra Palm scan program, not exactly cheap, but it has alot of capabilities.
    Be sure exactly what it will do. If it will not monitor or freeze frame, it is just a code reader.
    OBD2 code readers just do that, read codes, nothing else.
    There are 2 tools that a mechanic cannot be without in these times, a scanner and a good information system. We use Alldata for our information system and our guys like Snap-On's MT2500 scanner (spendy), Auterra's Palm unit, AutoXray, CarCode's PC based scan program and for European Imports, CarSoft's PC based scan program (spendy).
    swschrad,
    Dodge.
    On their vehicles with digital dash, there is a provision for pulling basic trouble codes.
    I finally got around to ordering a box to put my code reader kit into, and the laptop has been tuned up and a good battery scared up for it. I get to play with it next week, albeit with the DOS program, the winslows one won't fit on the hard drive. it's just a trainer for me, anyway, and an excuse to play around and see if I can justify a real laptop whenever the phone business picks up again, so that works.
    Many thanks, again, for your great info. I'd like to get into some electron driven car magic!
    I had to post this info. even though I wasn't going to post until I had some codes to share.
    I went on a little trip this weekend and got a chance to spend some time on the expressway. I noticed after a quick little 45 min. drive that my check eng. light had turned off. I then drove the return trip, and at some point it came on again. Nothing too exciting really, this has happened all along. But, then the next day I take an hour and a half road trip and the light is off again upon the destination. Then after the vehicle sat for a couple of hours I drove a short distance and while idling the light came back on again. I then drove the return trip (1.5 hours), and near home I stalled at a stop light. I restarted and it wanted to stall again.....put it in Nuetral and kept it running. Then it stalls at the next stop light, and then the next. At some point I got out of stop and go, and it ran fine again. I later took that 45 min. trip again, and you guessed it-the light was off again. It remains off today as I have taken it into the shop this morning.
    The mech. said this actually could be the O2 sensor. (It was supposedly replaced a month or so ago) It looked new and shiny though.
    The last code we got on this thing pointed to the O2 sensor....but it was new then too.
    Anyone see any correlation here at all? Should I drop the $$$ again to swap in a new O2 sensor???? Based on this new series of events, does it sound like an O2 scenario? How about an idle problem? Just thought I would throw this new info. out there and see what anybody might think. As always thanks in advance for your thoughts.
    Well I just heard from the shop and the news wasn't that great. Still nothing definative. They did get an O2 code, and a "lean" code this time though. But, the O2 sensor appears to be working properly right now. I wanted to post this in case anyone has ever seen this before with a 4Runner or anything else for that matter. Thanks as always.
    I reset the light last Thursday night by disconnecting the negative terminal for 10 minutes. On Friday I went on a weekend getaway drive to New England. (I certainly did not want to look at that light the whole darn weekend). I drove over 700 miles roundtrip. Other than it being lit at startup for a few seconds, the light did not turn on the entire trip. I still think that the gas/gascap/stop-go traffic had something to do with it lighting the first time last week.
    I still say if its a one time occurance let the &*$# light reset after a couple of engine cycles or let us easily reset it. Why does one have to wait so long time and look at that %&*@$! light for something minor. (Someone said earlier, maybe 50 or so complete cold engine starts to normal operating temperature?)
    The SES light causes so much axiety for people not experienced in diagnosing the problem. It seems senseless to have the same light indicate everthing from a major engine control problem that will destroy the engine to something that is really minor, like a loose gas cap. It like having a smoke detector go off everytime you light up a cigarette or use the oven and not having it go off for a week, a month or more. Try living with that.
  • mrdetailermrdetailer Member Posts: 1,118
    This is not the one where a can is put in, but a full decarbonization through a mechanic who puts it on a machine for about 45 minutes. It cleans not only the valves and fuel injectors, but the O2 sensor, and catalytic convertor.
    I think it's excellent preventative maintenance every 50K.
    I never heard of a 45 minute engine de-carbonization treatment. Although I recall hearing of some redneck mechanics pouring auto transmission fluid down a carburator years ago when we still had carbs. (I think GM called their through-the-carb engine treatment "Top Engine Cleaner").
    But isn't that what detergent gasoline is suppose to do? Mobile ads sez "drive yer engine clean". I think it helps keeps carbon buildup to a minimum. I would hope that it also keeps the O2 sensor happy too.
    jasonsilb,
    I know Alcan and myself have said this several times. An O2 sensor trouble code does NOT mean that the sensor is bad. It is a problem with the O2 reading or circuit.
    Now, this could be a bad O2 sensor, but it can also be a vacuum leak, exhaust leak, bad O2 sensor wires or a fuel pressure problem.
    If the mechanic hasn't checked fuel pressure, checked for vacuum leaks or exhaust flow, then those are some things that should be checked if the O2 sensor itself is reading fine.
    warrenul,
    Most trouble code diagnostic trees/flowcharts, the first thing on the diagnostics is to clear the trouble codes, road test and then recheck the trouble codes. Sometimes the light will come on because of a fault that is an intermittent and will clear itself. Some instances of this are poor fuel qulaity may cause the O2 sensor to illuminate when low on fuel. When the vehicle is fueled with good fuel, the system "sees" no morre fault.
    warrenul,
    Don't confuse GM's Top Engine cleaner with a de-carbonizer. It is designed to remove varnish that is built up from oils and fuel. Detergent helps prevent varnish and carbon from building up, but it still builds up.
    GM's Top Engine cleaner is designed that you pour it into the intake while it is running, then you purposely pour too much in until the engine stalls. Then you are supposed to let it set, while the cleaner softens any varnish build up.
    The injector cleaner that mrdetailer is confusing with a de-carbonizer is a cleaner that is run thru the injectors. It is designed to clean inpurities from the injector tip and clean oil and fuel varnish from the combustion chamber.
    Carbon is not a major issue anymore, unless the vehicle is neglected. If there is a carbon problem, then it will affect the entire fuel management system.
    and both are reputed to do a good job at clearing the injectors of varnish and crud. they attach instead of the fuel pump and hoses, and have a little gas in the can along with a ton of injector cleaner.
    I wish you would tell GM that carbon buidup is not a problem in the newer vehicles anymore, that's the reasoning they put behind the "engine knock" issue on the 99 & up Silverados that are experiencing engine knock at startup. The first thing they want to do is a decarboning of the engine (at owners expense)I told them if there is a carbon build-up problem on a brand new engine then they have issues with their computer setup for running these engines. But I was speaking to a dead horse of course. LOL
    Ray T.
    The problem with their theory is that I have had those engines apart and they looked pretty clean to me.
    If carbon were a problem, as they say, the fuel management system should have a fit. The emissions should be off the charts. Carbon build up is cause by unburned hydrocarbons or contaminents in the fuel. If carbon build were the problem, then it should affect the O2 sensor.
    Once again, I am amazed at your brilliant insight. No this isn't the beginning of an elaborate insult! I really mean it. To what do you attribute the knocking problem in, for example, some of the 1990's vehicles? I had a 1993 Explorer that got to where it would knock some in the mountains here, and I thought that I got some relief from that by using "good" injector cleaners and occasionally mixing in some high test gasoline to raise the average octane rating. The cure to the problem came when I sold the vehicle! (:oÞ
    fleet,
    Ha ha, thanks! Believe it or not, I can't hold a candle to alot of the mechanics I deal with on the automotive stuff, including Alcan.
    I'm not sure exactly what the problem is with those engines, but it would seem to me that there is a problem with a couple things. One being an oil problem. Since it seems to be a cold start knock, then it would make sense that the one or several lifters are bleeding off.
    Another thought is a spark knock situation. I have dealt with one truck that the guy pulled the engine down, installed a new cam and lifters and put a performance PROM in the ECM and reprogrammed it for performance and the knock disappeared. I told him I wished he would have first installed the chip, because I would have liked to seen if the chip alone helped the problem or not. He hauls a race car trailor and is a power nut. LOL!
    Well I like to keep you all updated, and 0patience-Thanks for the comments, they are helpful.
    I did have an "induction cleaning" the last time my 4Runner was in.
    I just got the latest from the shop: The fuel pressure has been checked, also no vaccum problems. They have gone through this thing again with a fine tooth comb.
    What they think is the problem relates now to a "rear-02 sensor"? I didn't know there were 2? (the main one has checked fine again and they are confident that it's working perfectly) But that we could be dealing with a catalytic scenario now. The light is off now and the mechanic drove the vehicle some 104 miles to see what would happen. That's more than I put on it weekly, so it should have done something like in the past. Well all is well right now. I am supposed to pick it up tonight and the mechanic actually said he would "...like me to take the vehicle and drive it for a week or so and see what happens" before I pay the bill again. Sounds like I only have about $150 or so into it this time (for the sensor). I pray this is the fix. (rear 02 sensor)
    Sorry for all the details, but figured it was warranted at this point.
    How does this sound to anyone? 0patience?
    Thanks for the comments, they do help.
    Well, it sounds like they are on the right track.
    And before I go into this any further, I must tell you that if this mechanic has narrowed it down and charges you fair, you should remember to keep him in mind for ALL your repairs.
    That being said,If there was a problem with the forward O2 sensor and it was replaced, there may be a problem with the catalytic converter, which would affect the rear O2 sensor.
    You may want to have the exhaust pressure checked before and after the cat. That will tell you the condition of the catalytic converter.
    Well the light has come back on the morning after I picked up the vehicle.
    0patience: I will refer this mech. to any and all of my friends, and continue to use them . They truly have been a good find. They keep apologizing for the mystery....but having said that, I realize the position they are now in. They are being more than fair and have more than established trust here.
    The mech. did say now, after telling him the light is back on, that the catalytic converter would be the next thing. He wanted to monitor the rear 02, after I fill up with some mid-grade and run out the premium currently in there?? He tried to save me from the $$$. I appreciate it, but it looks like $500 or more. I can't believe this ordeal. The vehicle only has 48K on it. All people/pros my mech. has talked to, have never heard of anything like this with a 4Runner or anything else. The sad fact is that the catalytic conv. most likely has nothing to do with the stalling scenario, probably only the check eng. light. It hasn't stalled in about 140 miles though, as of right now. Maybe the additive did some good here.
    I guess we are on the right track, but somehow, this seems so wrong. I am going to stop here because I think we have exhausted all possibilities and it seems like my shop is doing all the proper procedures. I thank all for the suggestions and comments and wish this story had a happy ending.
    JS
    The best thing for your mechanic to do is to use an exhaust pressure tester before and after the cat. It will show easily if the cat is plugged, which from what you have said, I suspect.
    Understand, that if the cat is partially plugged, the engine can stall. You see, if the air going out of the engine is stopped, then the air coming into the engine is stopped. No air, no fire.
    This article may help shed some light.
    if the cat is full of carbon, it was put into trouble by bad ignition letting unburned gas into the exhaust. once it gets restricted, you could be on a treadmill to plugging it.
    Well.....
    Not always the ignition. More often than not, there is a fuel management problem. Whether it is a vacuum leak, exhaust leak of fuel pressure problem.
    If the forward O2 sensor was a problem and it was verified, then it would send a bad fuel mixture thru the cat. If the O2 sensor went bad, then it must be determined why it went bad.
    Again, vacuum leaks, exhaist leaks, bad wiring or a fuel pressure problem would contribute to contaminating the O2 sensor and cause it to go bad.
    Just to add to Opatience's post, carbon in the converters isn't what plugs them. The chemical reaction which takes place when hydrocarbons (unburned gas) contact the catalyst in the converter causes it's temperature to increase. If a rich mixture or misfire is dumping lots of hydrocarbons in, the converter works overtime and it's temp goes way up, causing a partial meltdown of the catalyst bed. Like Opatience says, replacing the converter is treating the symptom, not the cause.
    Does anyone know if the 02 sensor is covered under the 80k warranty the gov. makes car companies honor? I was just informed that the catalytic conv. is most likely covered, but what about 02 sensors?
    Thanks.....
    as that is the primary arbiter in setting the fuel mixture.
  • depawldepawl Member Posts: 6
    Could someone tell me how to reset the SES light on my 1998 GMC Jimmy? I've had it in to my mechanic a couple times (whom I have pretty good faith in) and he said he gets a "misfire" code on his computer but other than that can find nothing wrong. If this matter has been covered previously in this board I apologize, I read through the first 100 or so posts until my eyeballs fell out and gave up.
    Thanks for you assistance.
    there is a code that actually resets the light, which can be sent from the reader.
    however, it might be a good thing to get a diag tree for misfire (it helps to know the code number) and work through it to fix the trouble first.
    more than you ever wanted to know about codes, and what sections of the drivetrain each one covers (code does NOT equal "replace this part only to fix your ride") is on www.batauto.com.
  • battalax2000battalax2000 Member Posts: 5
    Have a 2001 Jetta Vr6 with 47,000miles. I was putting on about 120 miles a day / 6 days a week for about a year..so they are all highway miles..car is less than 2 years old, and at 41,000miles my check engine light comes on. car's acceleration is terrible now, and my A.M radio reception is now lousy. Smithtown VW replaced knock sensor, cam sensor, knock sensor. In that order, all after about 20 miles the check engine comes on again..acceleration is still terrible. These guys are professionals? $650 bucks later they take the car in for 10 days, now they think a wire in the harness is shorting. But it is in the harness so they have to replace the whole thing...$1100 dollar job...finally got VW to "good will"me the harness at $400. got the car back 10 days later accelerating better. but they did not hook up speedometer. told the dealership I thought the 8 hours labor was unfair, since they just kept replacing sensors that already costy me $650 needlessly....Lou the service mgr could care less. and in between all this my window falls into my door...apparently the plastic that holds up the windows is shattering on a lot of vehicles. I was pissed could not get my window up...I have leather interior, what if it rains? They fixed it supprisingly enough that day in 3 hours....anyway after they did the harness, 10 miles later...guess what....check engine on again...and I find out they set back the timing or something so that I would not notice the loss of acceleration as much...I used to redline at 65oorpm they set it back to about 5100rpm...did not even notify me...seems a bit much....the smithtown dealership in NY is terrible, service is the worst .....the whole ordeal with the unfair pricing led me to telling my story to someone in the showroom, and they went crazy...when I asked the for my receipt on the window repair they refused, so I told them I would not leave without it...and they called the police....what customer service..anyway got to tell my story to 3 other police officers...who would not by a car from that dealership...guess I got something accomplished..any one having similar complaint son windows, radio reception shorting out sensors...service similar to what I got at SMITHTOWN VW in NY? VW customer service is of no help, they say they can do nothing about dealerships the yare independent franchises? Who polices the dealerships? doesn't VW of america care...finally got an address from germany, will keep them posted...and they tell me ther eis no one else I can talk to ..no mediators? is this true....? I kno wI am rambling but I am so frustrated at this point....Thsi car was great till I got to 40000 miles...is that all $26.5K gets me? someone please help......
    On the work order, did they put what trouble code they got? If they did, we need that.
    If they didn't, then you will need to have the trouble codes retrieved and let us know what they are. We may be able to help determine why they are having troubles finding the cause.
    RE; Post #697, 2000 Windstar 3.8L,62k miles, code P1518 Intake Manifold Runner Control Stuck Open. Had the van in for this service today, mgr. says need new intake manifold. Also have bad driver side door switch, won't work w/remote opener. Warranty Gold covering the repair based on my "Diamond Plan" ext. warranty purchased from them. There does seem to be an issue w/vacum line to the vacum regulator on the manifold, they call it a "hose" which is not covered and Ford calls it a "line" which should be covered, in any event it needs replacement also since a slight leak has been detected and it will effect engine operation. I just love how they argue over "verbage".
    Thanks for your help identifying this problem, based on this vans history the ext. warranty is going to come in very handy and pay for itself over & over again.
    Ray T.
    Why are they replacing the intake manifold?
    The IMRC is replaceable. But if it is covered under warranty, I guess why not?
    Glad to hear that it is getting taken care of.
    THANK YOU!! For letting me know. I really appreciate the feedback, as not many provide it.
  • gekko2gekko2 Member Posts: 87
    Try disconnecting the negative battery connection for about 30 seconds. This should reset your ECU and thus reset Check Engine Light. If the light comes back on, you know the "problem" still exists and you should then have the code read by a mechanic with the proper equipment so you can find out what needs to be fixed/replaced.
