Get the van back friday since they had to order the part. I will be asking to see the defective part since I am also skeptical as to why replacement was needed over repair. Will let you know when I here.
Ray T.
Ray T.
It makes no sense to replace the manifold and not install a new IMRC.
Is it the same trouble code?
Have a CEL that goes on a lot-some emissions code and the fuse is a fast way to reset.
If you read thru this topic, there are links to some scantool options.
Tech Notes: CL display smoke test EVAP tests found IMRC not moving properly.
Ordered lower manifold with runners removed ($395)and replaced lower manifold and intake gaskets, replaced vacum line.
My question, why would they order the manifold without the runners???
The Windstar seems to running fine after tech switched the two vacum lines around that caused the light to come back on 10 miles after initial repair.
All in all it was $923 just for this portion of my service visit, all covered by my recently purchased Warranty Gold extended serv. policy (thank goodness).
Ray T.
Since it was a warranty item, they went with what they new was going to fix the problem one way or another.
The runners are probably not a covered replacement item, so the probably saved the old ones. Or, it may have been an update on the manifold.
I recently came across an article on the Caravans where the fix for a problem was to remove the knock sensor. Not replace it, remove it and tape up the wires. If it hadn't been a factory bulletin, I'd have never believed it.
next factory bulletin: ignition change... remove (laundry list of items), add coil, condensor, points, distributor, cap
I have a 2000 4Runner. I noticed nothing different about the car's performance when the check engine light was on.
The check engine light comes on because it detects a fault in the system. Systems after 1996 are OBD2 and require an OBD2 scantool to retrieve the trouble codes to determine a starting point as to the cause of the light coming on.
When the light comes on, the system may go into a default mode and run fairly normal.
Once you have retrieved the trouble codes or had them retrieved, we can give you an idea as to the cause.
In my case, it was on a new Villager Mercury with about 6K miles on it.
One month went by with out a hitch, but the same warning lights have returned after it went below half a tank.
Lastnight I replaced the air filter, the gas cap and filled it up with Mobile gas instead of the usual Citgo or Sheetz. The lights went off. Any thoughts what this could be?
So far two days without the lights coming back on. I plan on keeping the tank above half for a couple of weeks, assuming the lights do not come on, I will let it drop below half a tank to see what happens.
Does the brand of gas matter, as in Mobile versus Citgo? I have always heard they get the gas from the same place.
Thanks very much 58VW
http://www.batauto.com/VW/
I loaned my car out over the weekend, and after filling up the tank, the "borrower" saw the check engine light came on. My first thought was the cap wasn't on tight. How do I disable the light, so that I can check my theory??
Steve Skyrm
skyrm@hotmail.com
local mechanic and the code P0172 came up on the
diagnostic check. Mechanic states "bank 1 lean
and vehicle needs to go to Toyota for ECM reprogramming" Called Toyota for appointment and
described problem to them and Toyota Service Department Rep states that reprogramming the ECM for a system to rich is not possible??
Any feedback would be
appreciated.(P0172 on a link from edmunds site comes up "system to rich")
Steve
ECM reflashing will not solve the problem.
99 Toyota 4 Runner
P0172 System Too Rich (Fuel Trim) (CA Only)
CIRCUIT DESCRIPTION
Fuel trim refers to the feedback compensation value compared against the basic injection time. Fuel trim includes short-term fuel trim and long-term fuel trim. Short-term fuel trim is the short-term fuel compensation used to maintain the air-fuel ratio at its ideal theoretical value. The signal from the heated oxygen sensor indicates whether the air-fuel ratio is RICH or LEAN compared to the ideal theoretical value, triggering a reduction in fuel volume if the air-fuel ratio is rich, and an increase in fuel volume if it is lean. Long-term fuel trim is overall fuel compensation carried out long-term to compensate for continual deviation of the short- term fuel trim from the central value due to individual engine differences, wear over time and changes in the usage environment. If both the short-term fuel trim and long-term fuel trim are LEAN or RICH beyond a certain value, it is detected as a malfunction and the MIL lights up.
When DTC P0171 is recorded, the actual air-fuel ratio is on the LEAN side. When DTC P0172 is recorded, the actual air-fuel ratio is on the RICH side.
If the vehicle runs out of fuel, the air-fuel ratio is LEAN and DTC P0171 is recorded. The MIL then comes on.
If the total of the short-term fuel trim value and long-term fuel trim value is within ±35% (80°C (176°F) or more), the system is functioning normally.
When air fuel ratio feedback is stable after engine warming up, fuel trim is considerably in error on the LEAN side.
Possible causes;
fuel line pressure
injector leak, blockage
Open or short in heated O2 sensor (bank 1 sensor 1) circuit
HO2S Bank1 sensor 1
Mass air flow meter circuit
Engine coolant temp sensor
gas leak on exhaust system
ignition system
ha ha ha ha ha \\\ slap! /// oooh, thanks, I needed that.
thanks in advance.
talking with the mechanic the diagnostic chart
comes up with a bad O2 Sensor. Mechanic does not
believe this to be the problem because he has
seen other 4 runners with bad O2 Sensor code and
they were replaced and problem was not solved. This is why he recomends ECU software to be updated. Although if I want they will gladly replace the O2 sensor. I have an appointment at
the Toyota dealership on Wednesday. Symptoms since
the light has come on 1 week ago
poor gas mileage 14.7 m.p.g. as opposed to the
17 to 18m.p.g. I usually get.
vehicle stalls sometimes when decreasing speed (manual transmission and stalls whether in neutral or in gear with clutch engaged
will check back on Wednesday with the news
Check engine light has been on for over 6 months. Dealership cannot pin point problem. Everytime something gets changed - the light pops up again. VW service is blaming a small accident in March on the problem and now won't cover under warranty. I took car back to body shop and they told me neither engine nor transmission was effected in accident. Each is blaming the other. I am going to a different dealership tomrrow. If I take the car to AutoZone - can they pinpoint the problem? I want to be prepared tomorrow. I really think this a warranty issue. BTW - Now the car revs up (surges?) the rpm when driving at 50-60 miles mph. This was not an issue prior to vw service. Any suggestions, guys?
I'm thinking I might get a simple answer by simply stopping into Auto Zone, getting it diagnosed for free, and - gosh, golly, gee - being told what the code is!
The second method (turning key from run to off 3 times within 5 seconds) seemed to work. A code of P 1684 was displayed. When I checked on this code (again through links provided here) it appears to be related to "the battery having been disconnected sometime within the last 50 starts."
Another link described this code as "a status indicator only - NOT a reported fault code." Am I to assume that this is not the cause of the check engine light coming on? I have never disconnected the battery on this car before, however I have never had the check engine light come on when disconnecting the battery on several other cars, so I think this code is unrelated to the real problem.
I wonder if I didn't wait long enough to see if other codes would come up, or if I need to press the odometer reset button (or some other trick) to move to the next code. Heh, guess I am just spewing my thoughts here... If I can get any more information I will let you all know.
Greg
Greg
Am I asking enough questions?
