A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
You install the software, plug in the cable and navigate the program.
Most are pretty self explanitory.
See for yourself.
CarCode PC based Scanner
Auterra Palm based Scanner
AutoTap PC based scanner
Ford Palm based scanner
days ago and it came on again today.
Got my NY state inspection days before.
How coincidental!
Has anyone here heard of anyone fixing their
CEL by getting a new gas cap? Thinking about
trying that first.
If that doesn't work I'm going to have to
go out and get a code reader.
ty
rd
99 c70
and read that if you reset the CEL by disconnecting the battery the CEL will only come
back on a short time later as this trick does not
actually clear the codes on newer cars.
Is this correct?
That's what I did as per my post above.
ty
rd
so all roads point towards your getting the codes read, consider what needs to be done, and then clear 'em after service.
autozone and many CSK stores will read your codes as a sales tool to help sell renewal parts. but the code results don't come out as, "EVIL! buy everything near this spot we have in stock right now, will that be cash or check?" the codes indicate a subsystem that should be checked with further diagnostics to determine what needs to be done.
detailed manuals like Mitchells, the OEM service manual, or Alldata will have the diagnostic trees the codes refer to.
A few weeks ago my 99 Volvo's CEL came on. [ Check old post ]
On a hunch I mail ordered a new gas cap thinking my original one is getting old and popped it in last thursday.
Went to get gas Saturday and WaLah, when I started the car the CEL went out and has been out ever since.
It may be a good idea to change all your fluid
caps and seals every three years or so. Gas, Oil, Coolant, Etc.
Hope this tip helps other motorist's in the future.
rd
99 c70
I have a 2001 Chevy Silverado 4 x 4 1500.
I have 60000 miles and now when I fill up with gas the gauge reads empty and the low on fuel warning comes on. the guage doesnt read correct until 30 miles or more.
I appreciate your help.
Wade
oh, surgical hose also seems like something I'd not want wrapped around my arm cutting a bolt off....
you'll miss the next summons to Herr Filchengeld, though...
After our local dealer replaced our head gasket (and valve cover gasket) on our 1998 2.4L Voyager with 52K miles (and being 5 years old: aka past all warranties, though DC Customer Service gave us a reference number allowing only a $200 co-pay for this service), we no sooner drove it home, and the "Service Engine Soon" light came on.
We brought the van back, they scanned it, and it reports as: "upstream O2 sensor stuck on center"
Me thinks they caused this problem with their head gasket/valve gasket repair, as when I turned the key on after picking up the vehicle, I noticed they reset the computer (radio set to 53 AM, clock time was off).
I suspect during their post check of their fix, the MIL was tripped as they some how caused the O2 sensor problem and they reset the computer (aka: PCM) so I wouldn't see the MIL.
Is it normal for them to reset the PCM after a head gasket repair (I think not!).
Thoughts and how to ask tactful Qs re: this to incriminate them?
I think I should follow up with DC Customer Care on this, it is just to coincidental that this MIL occurred after their work, yes?
It is very common and in some cases has become common to replace the O2 sensor as part of the head gasket replacement.
As part of the repair, the trouble codes should have been checked and cleared.
So no, it is not likely that the O2 sensor is caused by something they did.
But.............
Yes, they should have checked it out and probably replaced the sensor knowing that coolant would damage it.
You're in a tough spot.
Incompetent? I wouldn't think so.
Inexperienced, sounds like it.
The clock is going to be off and the radio presets will be lost.
I'll probably call DC Customer Care and ask if the O2 sensor should have been replaced during the head gasket repair job and/or if there is any assistance the can offer on the $200 the dealer wants to replace the sensor.
Thanks again!
It lit up two weeks ago and I reset the light again. However,I did notice that this time, the car was prone to stalling only when depressing clutch and letting up on the gas.
I knew that there was definitely a problem and brought it in to the dealer (SES light remained off). They put it on the OEM Diagnostic machine , however, no DTC codes were stored in the car's ECM control module. They performed a Idle Relearn Procedure and readjusted the idle a bit higher.
After reading extensively on this subject from you guys, I thought that stored DTCs could only be reset using a scanner/diagnostic tool. Otherwise, I think that it would have better to leave the stored codes for the Technician to pull to see if it was related to the stalling condition.
I would have like to confirm that the illuminating of the SES light was directly related to the stalling that I eventually experienced. However,I don't know why it didn't light up when it was kept stalling, or is it possible to have the SES light without storing a hard code?
PS: I am looking to obtain the Equus 3100 OBDII Reader. I think that for the money, its a full featured unit. (Well under $200)
Yes and no.
Sometimes, it is possible for the light to illuminate, but not store a hard code.
That being said, most often, it will store a code, but the scantool being used will not be able to retrieve it. If it is a manufacturer specific code, then most generic scantools will not be able to bring up the trouble code.
For a problem like that, take a look at this one.
Before you decide on the Equus scanner, read this Equus review article.
Then read the rest of the scanner review articles.
We are currently working on a review of Enginemate.com's new scan program. It is the first one we have seen that works off of a Windows CE handheld PC.
The one they sell with it is the Dell Axim.
I had previously read B's article on the Equus unit and saw that he gave a favorable review on it. Although the article didn't state whether you also agreed, as the unit tester.
Anyway, the SES lit up on my car again 4 days after getting the car back from the dealer. They told me that a P0420 was stored on the ECU. Although this indicates a problem with the 3 Way Catalyst, they are attributing the MIL indicator to a problem with the car's original ECM program. They are only updating the car with a new ECM program and sending me on my way. (Nissan TSB NTB00070)
I can't imagine that the SES light did not light up after driving the car over 2 and a half years and 40,000 miles. I hope that this resolves the SES problem once and for all.
Thanks for your technical expertise, as always.
http://www.davisnet.com/home_static.asp
it wants 32-bit MS Windows, and the PDF users guide posted specifically says it works with Windows 95 through XP
http://www.davisnet.com/product_documents/drive/manuals/carchip.p- df
so you're in like Flynn.
It will do the things that you are looking to do, but...
Since I try and stay unbiased on these products (not always easy to do) and recommend products that will do the job, for the money, there are other units that will do more.
If you want to only pull the codes, clear the codes and basic emissions diagnosis, then the Equus is the one for you.
It is a great tool that will work great in the "what is the problem?" category.
The next step up is the "why is the problem there?" category. Which is where some of the other scan programs are.
I guess my best recommendation would be, look through and see what the scanners and scan programs can do, then figure out what options you want to be able to use. Then see which ones fit in your budget.
Also, pay particular attention to what can be upgraded and updated.
Important
DO NOT coat the spark plugs with anti seize compound. Over torquing could occur and damage to the cylinder head threads may result.
Thanks for the advice, I'm going to head over to auto zone right now if they have any spark plug thread chaser. I still have all four of the old AC41-928 spark plugs, there is alot of motor oil looking grime on the thread of the spark plug and "little" pebbles. is that carbon buildup?
remember to go slowly and try hard as you can to get the chaser started straight in the hole. if you chase "crooked", the whole thing will be cross-threaded.
if the worst occurs and the engine block threading is too badly stripped or thinned to allow installing and holding a plug, there is a Heli-Coil kit that can put a threaded repair plug into a larger drilled hole.
I have not been there, and strongly suspect the cylinder head would have to come off to catch and clean all the drill and tapping chips from that operation. thus I'd figure on being towed to a shop myself for that operation, as I have not been an engine-opener.
If you put grease on the drill and tap it will trap the chips so it can be done installed.A very old mechanics trick.
Unfortunately, yes it is possible.
Which is why most mechanics recommend replacing with the same brand and number plugs that you took out.
When re-tapping a spark plug hole bring the piston about halfway up on the up stroke.
Fill the cylinder with shaving cream [yep, that's what I said]. Tap the spark plug threads [work fairly quickly, as the shaving cream will eventually melt], when finished cleaning up the threads, use a breaker bar and socket and turn the engine over to push the shaving cream out.
Once the metal shavings are out, you can use the starter to crank it over [disconnect the coil or connector to coils] to push any remaining shaving cream out.
Put the new OEM [usually AC or something like that] plug in and start the vehicle and let it warm up. Recheck the spark plug and then you should be done.
It sends unburned hydrocarbon fuel into the catalytic converter, raising the temp of the catalyst bed to where it eventually melts down.
"should I believe what the dealer said?"
Depends on which diagnostic trouble codes were retrieved:
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
P0307 Cylinder 7 Misfire Detected
P0308 Cylinder 8 Misfire Detected
If there are no driveablilty issues, have the codes cleared and drive it. If the codes reset, take a hard look at the quality of the plugs and wires (a lot of aftermarket stuff is sub par), and if all's ok time to lok at the coils.
I'd like to take credit for that idea, but it was passed on to me by another mechanic.
It works great, the shavings get trapped in the shaving cream and is pushed out the cylinder along with the shaving cream.
However, I will remember this one as your idea.
3 months after my warranty expired I was told I needed a NEW ENGINE!!! (I had 56,000 miles on her) I've been a Ford fan my entire life....(I still own my first car...1968 Mustang) but since I was screwed over by Ford (quite a few times) I might have to buy a Chevy! (or worse, a FOREIGN CAR!!)
for instance, what were the codes, and why didn't they count? there ought to be some service information out there at the dealers.
