DIY Front Brake Job - 2007 Dodge Charger SRT8 Long-Term Road Test
Edmunds.com
Our 2007 Dodge Charger SRT8 needs front brakes, so I bought some new Brembo brake pads, drove home to my garage and got to work.
1
I can see paying that kind of premium when you have a breakdown and need parts TODAY, but for something that's been in the planning stages for awhile like this...? I would say it's those dealers' lucky day rather than yours.
1) How hard was it to pull the tire's rim off the hub? My 2013 F-150 with Aluminum Wheels almost welds itself to the steel hub. The only way I've been able to get the wheel off the truck is loosen the lugs, put the truck in reverse, chomp the brakes, put it in drive, chomp the brakes (rolling about 2 foot forward and rear), jack the truck up, take the lugnuts off, and pulling the tire. I've tried beating it with a hammer, but no luck.
2) If replacing the Rotors, wouldn't it have made sense to look at a rotor upgrade? See what option you had?
On a side note, what happened to the shop with the 2 post? I use jack stands because I have to, but if I had easy access to a lift I would use it as much as possible.
Twitter: @Edmunds_Test
Damn...look at those clean fasteners and threads...the ventilation web between the rotor faces is not even corroded...you don't even need a wire brush.
Do they even SELL PB B'laster in California?
When you stop to think about the fact that this includes getting the repair order and finding the car. Then do what ever testing is required to confirm what it needs. I.E. road test, rack and disassemble for inspection which includes making all of the correct measurements (mic the rotors). (NOTE: The tech may even be required to machine them to prove that they cannot be returned to service and that does not pay additional time)
The tech then has to get the authorization to do the work, secure the parts, do the repair, and then road test to confirm that the repair is complete and correct as well as burnish the pads, I wonder how many people could actually work mistake free at such a pace?
NEVER, NEVER use anti-seize compound on fasteners
