Stories of INCOMPETENT MECHANICS - post yours!
24
  • amarmistryamarmistry Member Posts: 15
    They are somewhere near Hoffman Estate/Schaumburg area in suburbs of Chicago.
    They repaired the ball joint(or something like that) and said that they use Genuine Ford Motorcraft parts and has 12000 miles/12 mos. warranty. The problem re-occurred after 3-4 mos and after I moved to NJ. I called them and they not only denied the fact that they use Motorcraft parts(nor they say they us it) and they cover my waranty only if I was in the area. I got it fixed in NJ. I asked them to pay me for it, they asked me to mail the damaged part(which was ridiculous). Usually mechanics discards the parts after they take it off and they know it.
    So I didn't have the part they used so couldn't do anything since I was far in NJ.
    Stay away from them if you can.
  • sunscreensunscreen Member Posts: 22
    At 45k, I took my 96 Dodge Ram in to get brake pads replaced. When I came in, my truck had 4-wheel abs. Few weeks later, while driving on the freeway, I had to make an emergency brake. Guess what? I almost got my passengers and myself killed! The pedal went all the way to the floor! Barely brake in time.
    I went to the Dodge Dealer at 50K. They asked me if I had my brake job done at Pep Boys.
    What I've learned:
    Brakes - Take it to the dealer
    Trans - Take it to the dealer
    Oil Change - Joe Blow can do it.
    Electrical - dealer of course.....
    2 cents
  • snurdlesnurdle Member Posts: 1
    I had the misfortune of dealing with these exasperating people on behalf of a colleague.
    Expensive, not at all knowledgeable, reticent to admit any fault can be attributed to their maintenance.
    I don't drive a Lexus but they seem to start out as fine cars. I would advise anyone in the bay area considering a purchase that there is a good dealer at the auto row in Fremont.
  • abkhanabkhan Member Posts: 5
    I had a oil change performed at the dealer because after buying a new car. I get three free oil changes. Normally I do them because I can buy the type of oil and fiter I like and the PROPER amount of oil I put in. I told the dealer that make sure I get 4.5 quarts of oil and he said we know what we are doing. After picking up the car looked at level and it was a quart more. Decided not to call the people who know what they are doing because they will say it is ok to have that much and drained the oil slowly till it reached the level that the manual recommended.
  • sandywillsandywill Member Posts: 7
    Timing is everything and this story is no exception, family of 4 just moves 400 miles to another state, 2 weeks later moronic 16yr turns left into me at a high rate of speed, totals car, need to buy another, get a used 92 Buick LeSabre.
    From the get go, realized climate control panel wasn't operating properly, but had awesome air, heat and defrost, so put it on the back burner of priorities. Few weeks later, figured out there was a problem with the compressor, froze up! If the car was running so was the compressor, coded the computer, I believe it was a high head pressure code. Took it to a BUICK shop, they had it 2 hours, called and said it was fixed, they had reprogramed the computer. Now folks, I know better than that, even remarked to the guy, didn't know you could do that. Paid my $60 and picked up the car. 2 miles down the road, it recoded! Translation of reprogram, disconnect the battery cables to clear the code and pray it doesn't come back.
    Took it right back, they had it 8 hours this time before they called. Said the evaporator core was leaking, which affected the dryer, yada, yada, yada to the tune of $1000. Now you must understand we just purchased this car 4 weeks previous from another dealership which at the time of sale offered certain gaurantees and warranties. Air-conditioning components included. So I apoligized to the guy and said hey, gotta take it back where I got it.
    Take it back to them, haggle with the general mgr for an hour and finally agree to pay for parts if they eat the labor, which was over half the bill. They had it for a week, call me and say there is NO leak and that they had run every leak test possible, even recharged the system with dye, NO LEAKS! They drove it, ran it, no leaks. Sooooooo, we pick it up, 2 miles down the road, it codes again.
    Get home, hubby digs out the service manual and in 20 minutes found the problem. Seems some idiot decided to bypass the relay when it went bad instead of replacing it, thus hot wiring our compressor. Bought the $20 relay, installed it in the parking lot and have had no problems in the 2 1/2 years since.
    So was the first garage trying to take me to the cleaners, you betcha!!!!!! We lucked out!
  • pete82842pete82842 Member Posts: 2
    A couple years ago I took my 95 Pathfinder in for some warranty work. Since I had almost 30,000 miles on the vehicle I decided to have the Nissan Service Center change out all fluids on the vehicle also. I drove back to my home which was 100 miles away, and parked the vehicle in my garage. That evening I was looking over the invoice, and noticed it said "so many units of" ATF fluid were added. (I had a manual tranny). So I looked in my maintance manual to see what kind of fluid they required for the 5 speed manual. They listed a 80 W90 gear lube. I crawled under my vehicle and opened the tranny plug. Sure enough ---ATF. I was pissed. I drove 100 miles with that ATF in that thing (at 75 mph). Called the mechanic the next day to complain. He tried to tell me I was wrong. Finally I got them to admit they screwed up, and that they needed to remedy the problem. He agreed and had a local shop perform the task for them. Needless to say my tranny started to go out 2 yrs later and 20,000 miles later. Wonder if this could have anything to do with that!!!!!!!! Hmmmmmmmm.
  • gtt1gtt1 Member Posts: 63
    About a year ago I took my dually in for tires, figured they could not screw that up. Wrong! After waiting 3 hrs for them to come and tell me that they had busted the old tires off and mounted the new ones they did not have the proper adapter to balance my wheels. Alot of hell raising later I got $75 off and went to a real tire store for balance. Also the 16 year old putting my truck in the bay cracked one fiberglass fender, which they did not tell me about! So for those of you in Austin Tx, it's the one on South Lamar.
  • luckymomluckymom Member Posts: 5
    We've got the ultimate in incompetent service depts down here in SW FL. We have a bought a brand new Monte Carlo in 4/99 for teenage son- actually HE bought it- at 5100 miles it needed new tires. Dealer said it was the way the car was driven. I argued with them, finally took it to Goodyear & Goodyear warrentied them. At 7800 miles, the tires were again shot. Back to dealer- still swears the problem is the kid's driving. Back to goodyear (gotta love them!) on to & 3rd set of tires. At 8000 the car goes into a complete spin for no reason. Towed to dealer- dealer swears it is fine- charges us for the towing. Hubby decided dealer had to be right- take license from kid & Dad's got a new car to drive. Kid says no way in he** he will EVER drive that car again. Interesting in itself- what 17 year old male won't drive a new car????
    Hubby drives car for just over 1000 miles- car goes wacky- starts trying to slam itself into reverse while traveling at 40 mph, and GOES INTO A SPIN! Hubby gets off to side of road and tried to floor engine to blow up motor. It wouldn't rev up. Tow truck driver picks up car hour and a half later. Walks up to vehicle and asks it it had been on fire? Humm, pop the hood, can't even touch anything on the motor it's too hot.
    At the dealer the next day- "There's nothing wrong with the car". That was December 15th. Car is still at the dealer- they've tried to give it back 2x- we refuse to take it. Nothing has been done, they aren't willing to give us any certification of it's safety (I already told them I wanted everyones business cards, so I know who I'm going to sue). We've had the GM regional service rep look at it- he says it's fine. He's the one that controls all the GM service depts in the area. As long as he says there's nothing wrong, no one will start to tear the car down and figure out what's wrong with it.. UGH!
  • guitarzanguitarzan Member Posts: 874
    Well, did you give your boy his license back? :)
    How did you figure out that it was trying to shift into reverse?
    Guitarzan
    Community Leader/Vans Conference
  • dave1442397dave1442397 Member Posts: 12
    I had 32,000 miles on my car when it overheated one day in June '95. I pulled up at my aunt's house in Bergenfield, shut it off, and the radiator blew.
    So I called the closest dealer, in Bergenfield, and asked for the service department. Some guy answers the phone, asks if I can hold, and (I assume mistakenly) leaves me on the line while he describes the various idiots (customers) who passed by his desk that day, and how he likes to "screw with their minds".
    I hang up, call Ford roadside assistance, and ask for a flatbed to take my car to a dealer near work, on Rt. 17 in NJ (forget the name...).
    Car gets there, they look at it, tell me they have to order a new radiator, and it will take two days. Oh, and they don't do loaner cars...
    Day 3. I call back, they say they ordered the wrong part, and I'll have to wait another two days, not including the holiday weekend. Ok, anyone can make a mistake...
    Day 7. Oh oh, we ordered the wrong part again. I ask if they plan on ordering the entire lineup of Ford radiators until they find one that fits, or if perhaps they could just look up the stock number this time? Oh well, this time may be four to five days...it has to come from Detroit. I was not amused. I call Detroit, ask if they can possibly speed the process up.
    Day 8. Dealer calls me! Wow, that's a first. Well, radiator has arrived, but people are very upset that I called Detroit...apparently they have a reputation to uphold, and they don't appreciate customers going up the line, so to speak. I act innocent, said I just wanted to see why radiators were in such short supply, seeing as how most cars use them, so somebody out there must make an extra one now and again.
    Radiator is installed. Car still overheating because the fan shorted out when the radiator blew. Which they didn't notice before, because of course the fan was hidden under a nice sticky layer of x-files green coolant. Two more days...
    Day 11. Car is finally ready! I pick it up, leave before the service manager notices me, and spend the evening removing various grease spots from the interior and exterior.
    That was it for Ford service. I put another 103,000 miles on the car after that, but never went near another dealer. I loved the car, but the service...
    No, he's still without it. Doesn't need one right now, all the cars are taken and his doesn't look like it'll be back any time soon.
    Hubby said you could feel the car trying to slam into reverse. Grinding, jerking, the whole bit. Said he'd never felt anything like that before in his life. Said it was like when you put the car into reverse too quickly and you're still rolling forward only multiplied tenfold. We just hope when they finally decide to lemon it (it's coming to that), they don't try and resell it. If I'd ever see it on the road (it is unique) I'd turn and go another direction.
  • jridgway1jridgway1 Member Posts: 13
    OK. This is a quick one. Took the car to a local firestone dealer for an oil change and lube. They were busy so had to come back and pick it up later. Just before quitting, car's still on the rack. They say it's done. I pay and they put the car down. Since they're closing they just let me drive it out.
    I always keep an eye on the oil pressure gauge.. notice that it never comes off 0 and immediately shut off the engine. And, now here comes the mechanic following the black trail out to my car. He has to clean it up and wonders where it leads to. He looks under the car.. Hey! No oil filter! and thanks me for not driving it home. Duh! More later.
  • edwardh1edwardh1 Member Posts: 88
    In Chas, SC - tech comes into the waiting room, holding my air filter, says "we recommend changing these every 15000 miles".
    I said I agree, and since the car is brand new (3500 miles) lets wait.
  • thebertstheberts Member Posts: 2
    Typically called "service" departments, I think most repair shops forget what the word service means. Most of us have experienced the "We'll call you" line where we end up being the ones to call back.
    Or, calling a week or two in advance to make an appointment for some minor (or non-urgent I should say) repairs only to end up waiting several days anyway simply because it is "first come, first serve". So what's the purpose of making an appointment?
    Finally, Pep-Boys - DON'T GO THERE. I've used them in the past and received quality work - mostly new tires and inspections. But they dropped the ball this last time. While visiting family in Pittsburgh one weekend, a rear control arm broke on my car. Being a Sunday, Pep-Boys was the only option. Any way, Sunday afternoon I am told they need to order the part from Chrysler Monday morning and it would be in on Tuesday. Fine I say. Tuesday morning, I call about noon. "How's my car". I am told Chrysler sent the wrong part. It was reodered and should be in on Wednesday. Wednesday I call - "How's my car". Wrong part again. Well I let the "service" manager have it, which resulted in nothing. Thursday morning no call. So I call again, car is fixed, but we have to recharge the battery so it will be done around 3PM.
    No discount, no reimbursement for lost wages, no apology, nothing. So from now on, I tell everyone not to go to Pep-Boys.
  • ebbgreatdaneebbgreatdane Member Posts: 278
    85 Toy again that I wrote about in Post #22 many moons ago...
    85 Toyota Truck: "I am over heating"
    Toyota Dealer: "Your head gasket has an 'external leak'. $900 to service.
    Independent Mechanic recommended by friend: "Your fanclutch has worn bearings. $70."
    Replaced the fanclutch-it's been 3 months without overheating...later
  • reddogsreddogs Member Posts: 353
    They replaced the brakes on my friends car after we both told them it was the master cylinder (brake went to the floor slowly), and cut the rotors to h-ll and somehow damaged the car alarm. When we brought it back, they charged for the master cylider and labor and refused to reimburse for any damages. We had to bend the regional manager into a pretzel before they replaced the damage they had done.....
    Good for nothing!
    Bought a new TC3 (Plymouth) years ago and a few weeks later headlights started blinking off and on as well as other accesories. I tracked the problem to water in the fuse box (you know, the one under the dash right next to the side panel)and took it back to the dealer and told them there was a leak around the front window. They said "are you sure you didn't leave your window down?" (like rain is anti-gravity and can go upwards under the dash). I say, no, the windshield leaks and leave the car. They call and say it's fixed (needed some additional sealant). A month later, went through the same thing (another fuse box). A few months later, same thing, this time the fuse box is completely corroded. Dealer says "We think you replaced this windshield yourself and it's not the right one, so you are responsible". This statement caused me to get upset and exchange words. Remember, this is a new car. They eventually, relented and actually got it right the third time.
    Within the year, that dealership went bankrupt so I guess you do reap what you sow.
  • cody_75460cody_75460 Member Posts: 3
    It has been almost 2 years since that frightful afternoon with my brakes. I had taken my car to an K-mart automotive where they said they had their best mechanics on my car, another repair shop supposedly messed my wheel disc so I was told and I bought 2 new discs for the front for about $180 labor and all, then brake pads and after the replacing the brakes I noticed they were not working correctly the mechanic said they were fine, I proceeded to drive and then before coming to a busy intersection I only had my back wheel brakes to depend on nearly cause me to vier into the north loop east bound traffic. I took it back to K-Mart where they said my master cylinder went out, this was on a 91' Ford Taurus. Well I had someone pull it home due to could not get the work done that day and they were going to charge $300 for that and come to find out when My uncle checked it. The problem was the best mechanic forgot to tighten the bleeding screws cause the brakes to fail and air to get in the lines. My uncle bled the brakes for free and it was fine after that. Be ware of repair shops take it to someone you have used and can trust.
    I bought a 98' Plymouth Breeze 1 year ago, after I had rid of my 91' Taurus. I tell you luck and cars with me are not in the same vocab. Well I took my Breeze to James Hodge in Paris, I had started hearing a clattering noise real bad and knew something was wrong with it. (Originally bought at Bohnam Chrysler) James Hodge told me it needed a tune up and I really gave them hell telling the the motor had been replaced 6mnths after I bought it due to previous owners neglect and that there should be no reason for a $350 Tune Up. I took it back to Bohnam and they found that it was an exhaust leak and repaired it for free. I trust Bohnam Chrysler repair shop and will only take my car to them, even if I have to have it towed.
  • sable93sable93 Member Posts: 107
    OH, I HAVE A GOOD STORY!!!!
    It takes place in Norristown, PA (just outside Philadelphia,) and involves my mom's '92 Ford Tempo GL. When she originally bought the car in '93, she got the extended warranty (60K.) At about 50K miles, she notices that the temperature gauge stopped working. She took it into Norristown Ford, and the Service Manager said they couldn't find anything wrong. He said "thats the way Tempos are." Funny, it worked right till then. She tells them to keep it there until they find out what is wrong. They give her a ride to work (in a different '92 Tempo.) She looked over at the temperature gauge, and it worked. She asked the driver about it, and he said they are supposed to work.
    To make a long story short, she gave them HELL, and got a new thermostat which fixed the problem.
    Stay FAR away from Norristown Ford! Don't even drive past it in your Ford product!
    Funny, Click and Clack (NPR Public Radio Sunday morning & Cartalk.com) responded in the newspaper that their experience is that Ford is notorious for bad thermostats. Knowing that, at a Ford dealer, wouldn't that be the first thing those schmucks would normally check?
  • brad45brad45 Member Posts: 27
    The drivers side window in my '94 cutlass coupe
    came out of track, and destroyed the entire track
    and window lifting mechanism. I brought it to the
    dealer, under warranty. They fixed it.
    Two week later it came out of track again. I
    stopped it before it ground to a halt, and gently slid it back into track.
    Brought the car to the dealer.
    They fixed it again.
    One week later - the same thing. I brought it back to the dealer again and their "best tech" said "Works good for me." I went to the car, rolled the window down 1/3 and with one hand slid it out of track, and said "It shouldn't do that" To be sure of my hypothesis the tech rolled the passenger side window down 1/3 grabbed the window with two hands and began trying to yank it out of track. Before I could yell at him to stop that, he came the conclusion that the drivers side window track needed to be replaced and aligned by the body shop. Brilliant.
    P.S. based on other experiences I too believe this mechanic to be their "best tech."
  • shekharpatelshekharpatel Member Posts: 27
    At best they do a shoddy job. They are capable of inflicting considerable damage on your vehicle. Many of us get roped in by their flashy ads :11.95 for Oil and lube, in under 30 min!. I have noticed that they always have a list of additional parts and services "ready" before you walk out of the premises. This is my experience of 2 visits from "econo-lube" in Columbia SC.
    Oil Change for Taurus: I Bought air filter from Auto Zone, replaced it and drove into the Econo-lube. 10 min later the mechanic came with a filthy air filter, told me -this is the condition of your filter and so it needs replacement. When confronted with the "Auto Zone" recipt, quickly acknowledged the honest (?) mistake and vanished.
    Oil Change for Altima: No problems untill the next day there was Transmission oil under the car. Took it to another repair shop to find -1 screw of the pan was missing and the adjacent 3 screws were ready to fall off.
    My conclusion is : STAY AWAY FROM CHEAP OIL-LUBE DEALS.
    I'd recommend sending a short letter to your friendly Attorney General and have them look into the way that shop operates.
  • ccabralxccabralx Member Posts: 5
    I bought a ’99 New Beetle and loved the car. I saw that the dash had lifted up in the driver’s side and heard a loud a tapping noise coming from the engine. When I brought it back to the dealer, one of the mechanics, who had worked on it all day, said that they were still learning to fix these cars. I told him that he shouldn’t tell that to customers – you know, so you won’t ruin their confidence in you (Duh).
    Well, after each visit I had my carpets well greased, new scratches in the paint, and oil-based handprints all over the front of the car, but still these problems persisted.
    I finally took the car to a different dealer, who saw the problem and knew how to fix them, but couldn’t because I already had a service claim against it. Here’s some good advice: The second dealership’s service manager told me to call the original dealer and ask to speak to the district service manager, and to have him or her meet me at the dealership to inspect the car. This way, nothing can be overlooked or explained away ( and the problems are logged by the district manager). When I asked the dealership to talk to this person, their tone changed, and they finally fixed the problems. If you are having similar problems with your dealership, you might want to try this tactic. Oh, by the way, I finally traded in my Beetle. I guess I lost confidence in it. Someday I might buy another one from the other dealership.
  • cgoetzecgoetze Member Posts: 7
    I had taken my car to a Jiffy lube for an oil change. About a week later I picked up a screw in a tire and went to a shop to get it fixed. While there they checked my tire pressure and then asked if there was a reason I had 60 PSI in the tires on the right side! Needless to say I was not amused, and when I went back to the jiffy lube to complain, their concern was, did anything happen or anybody get hurt? No? Then what's the problem? The free oil change they gave me found its way, very quickly into the trash. They had their chance at me, and I do not give second chances when I receive service like that.
  • 79377937 Member Posts: 390
    All I ever want these people to do is listen to me and do what I want them to do. "ONLY CHANGE THE OIL AND FILTER PLEASE. Don't touch ANYTHING else." What happens? They come and tell me the air filter that I put in last week needs changing. Or, they pump up my tires to the wrong pressure. Or, my pcv valve needs changing they say. Car has only done 10k! Or, they argue with me and tell me that my car has no chassis grease points - it's sealed. Tie rod ends have indeed got 2 grease nipples but their stupid computer is telling them that my model car has none. No thanks but thanks, I'll do my own oil changes from now on.
  • mpevznermpevzner Member Posts: 41
    Bought a brand new Galant ES V6.
    Had a rattling noise in the dash and an oil leak.
    Made 6 visits to these Authorised Mitsubishi dealers. They are the least competent people in the automotive industry, that I have seen so far. They never fixed either of the problems. The Mitsubishi representataive got involved but couldn't help me because he cannot go and do it himself, and the mitsubishi repairmen seem to be a bunch of high school dropouts who have to hold wrenches in their hands for the first time in their life. I don't flame all of them, just the ones I have seen.
  • trippdoggtrippdogg Member Posts: 19
    Back in highschool I went ith my friend bring his mom's car to the local Grease Mnkey for and oil change.... Everything seemed to go well until about halfway home, the literally died.
    To make a long story short, the knuckleheads at the place didn't put the right oil filter o, basically making a BIG MESS and causing the engine to seize....
  • southwestwormssouthwestworms Member Posts: 2
    Buddy of mine got an oil change a few years ago , K-Mart I believe. He had driven not one block when he noticed that the hood had a dent pointing north. It seems they didn't screw the cap back on. He was just about to go on a 300 mile trip.
  • orlockorlock Member Posts: 25
    I work in a parts department at a dealership.
    The most frequent mistake is the person wanting the parts gives the wrong information includeing year, side (left, right, front, back) or completely giving the wrong name (wants brake pads, but asks for master cylinder instead).
    The books and computers can be wrong. There are often updates to solve some problems. There's probably 500,000 different part numbers that we can deal with (no way we can stock them all and even the depots don't stock them all) and mabey 1-10 thousand errors depending on the updates and the year the product deals with.
    The depotsometimes ships the wrong part. I order a couple of mirrors and the depot sends me two hubcaps. The white tag has the part they sent me and the blue (the local depot, but other depots have their own colors) tag has the part number of what I put in (they must match with the white tag).
    The part is sometimes misboxed. The part number on the box/part is correct, but the part is completely different. This guy comes in with the old part and the original box. It's a round short plastic tubeing that goes on the aircleaner. I order four of them and they were all square holes. Call the main depot (the guys with the blueprints to tell us what really is suppose to be in those boxes) to do an inspection and they said they had nothing in stock to inspect. Customer got upset and we couldn't do nothing but order the wrong part till the depots ran out and had to order more (hopefully the correct ones). We also had a problem with getting the wrong sides in the window motor kits.
    Typos sometimes happen. Since the parts are written up, usually slopply, by hand I might misread a number and the number I put in turns out to be a good number. This happens only a couple of times a year. More often they write down the incorrect number or look up the wrong part.
    Our customers are starting to get meaner and less observant.
    One our service guys had is quote off by $1,000 and wanted the parts for free and at worst cost. It took 20 minutes to convince him the parts department wasn't a non profit organization (and our service department has to be reminded on a daily bases).
    Another guy was told his parts would probably take five days to come in. It took four and he didn't want it because it took to long.
    Another guy comes in and the part had been superceded to another part. He complained the part didn't look the same. It took a hour to tell him the definition of supercede.
    People are constantly buying parts for their trial and error scheme. Once the part is put on, it's a used part. We don't sell used parts nor can we return used parts. We constantly have to take the parts back because the management and the vehical companies demand we have happy customers, because they are interested in the customer coming back for a $20,000 car rather than fighting over a $20 part. Our department gets the money for that $20 part and not the $20,000 car.
    On a similar note I went to a grocery store and this woman in front of me at the cash register had $200 worth of groceries she took home, but her mother refused to pay her back, so she returned the groceries.
    The world is I want it now, in good codition, to my specs and for free.
  • eharri3eharri3 Member Posts: 640
    A 90 Mazda MPV. Not running. I push it to a mechanic five minutes from home reccommended by a friend. He say's he'll call in a couple days. I wait. He calls to tell me I need a new alternator. I tell him do the word. He does it, but it still won't work. He says I might also need a new distributer. He does that work. Then he calls a few days after that, says it needs a starter. But it might take awhile, the part eeds to be ordered. He says he'll call in a week. He doesn't. I go to his shop. He says expect to hear from him in another few days. I finally get my van back, with a hefty repair bill, over a month after I handed it over. And it dies within a few weeks again.
  • jwkessler1jwkessler1 Member Posts: 99
    We live well out in the boonies, but for some reason there is a fairly large, country Ford dealer about 3 miles from home. I've taken my Escort to them a few times and the service seemed ok, and the folks were nice.
    My 80 year old dad's 89 Ford Probe failed to start - wouldn't crank over all the time. So he drove it to the country dealer.
    Their diagnosis? The radiator was leaking, and it blew coolant into the alternator, ruining it. Both needed replacement. The cost would be nearly $1000.
    Dad's not wealthy, so he limped home with the car still unrepaired. He then took a close look himself. He could see no obvious coolant leak.
    Then he noticed one of the battery terminals had a poor connection to the cable. A $2.50 terminal fixed the problem.
    I just ordered a new Focus. This dealer offered me the lowest price, but I chose to go to a different dealer 25 miles away. Any guesses why?
  • fylertoofylertoo Member Posts: 2
    I own a 1995 Hyundai Accent it has 39,900 miles on the car. It was my aunnts' car. Faithfully serviced. I took it in the other day for a front end noise which ended up to be a need for a front end rotor. I go to pick up the car and they tell me that they took it for a test drive and the car died and that they had to tow it back to the garage. At that point they got into the car and it started right up. Anyways I go to pick up the car the next day pay the bill it runs fine. I get on the highway I 'm doing about 60miles per hour and this horrible knocking starts to happen. I take it back to the dealer.
    They say they will check it out. They call me back later and tell me I need i long block and the cost for installing that would be 2,700.
    Up to the point of taking my car into this dealer the car ran fine I've replaced a battery. Other than that this car ran fine.
    Has any body out there experienced this kind of problem
  • mikeglynnmikeglynn Member Posts: 6
    during a routine inspection approx 3 months ago my mechanic damaged the underbody of my minivan. this just came to my attention via chevy maintenance dept manager. he told me there is extensive sheet metal damage due to being improperly hooked up to a dynometer. hooks should have been attached to frame. i wasn't told of damage done by independent mechanics shop, therefore i now also have a rust problem where the damage occurred. the chevy manager told me the car jumped off the rollers also. i spoke to the independent mech. and he said, " i've never had a car jump the rollers" to which i replied, "are you always able to oversee all of your workers?" he then changed his tune, and said, "bring it in and i'll look at it ." what should i do if he denies it happened there? is he criminally liable for failing to report the damage caused in his shop? please help. thanks
    A coworker's wife took her older, high milage, but running well, Camaro in for a tuneup last week. Ric, her husband recommended a mechanic he has had excellent luck with, but she insisted on going to her favorite.
    First they charged her about $200 more then Ric's guy would have. Then as she drove the car home after the work, the engine began making awful noises. She brought it back immediately. They told her she must have done something to it. Surprise!
    Well, sure enough the engine was toast. Ric had the car towed to his guy where he learned they had flushed out the engine, a no-no with a car with this many miles on it. The gunk pluged up the screen on the oil pump, which they didn't bother to clean. The result was an oil-less engine.
    So Ric took her back to the butchers (sorry to any real butchers reading) that caused the damage. She was in tears - she loved the car. They refused to accept any responsiblity for the damage. As Ric's wife left in tears, Ric saw the mechanics laughing about it.
    He went in and read them the riot act. He must have done a good job, because they finally agreed to replace the engine. Further research has turned up a history of this type of work at this garage.
  • pttaylorpttaylor Member Posts: 34
    I went all the way through the BBB to the state capital department of consumer affairs after this "THIEF"! Here's the deal. Took my 1998 Dakota to his shop after Daimler/Chrysler refused to replace my ruined rotors (13K) and they claimed the failed pads were not covered but for first 12K! That's aother story. (Arbitration JOKE!) Anyway, this "THIEF" who put my new rotors and pads on had a 12K/12Mo guarantee on all parts and labor. I noticed that he had tacked on a $50 inspection, adjustment and cleaning fee for the rear brakes without my permission for the work to be preformed. (They adjust when ever I backup, as in every day!) He was very upset that I would question this obvious padding of the final bill eventually agreeing to do an oil change and rotate my tires in lieu of cash refund. When this was done, it was approximatly 2 weeks later that I noticed 2 lug studs broken, missing and all the studs were nearly striped from applying the lug nut with an air wrencch before starting them by hand. I discovered this when I had new tires put on at another shop. I took the truck to his shop and after he looked at the damage he said I couldn't prove he did it! He DID do it because nobody had touched the truck since he had. No relief. Fast forward to 11.8K miles on the pads and rotors. Worn to the point orf ruining them again! Took truck in within the limits of the guarantee and was told that I would have to pay an unmentioned fee for brake inspection (as above) before replacement pads and rotors would be considered. BS!!! And he then proceeded to tell me to leave the premises! First stop was BBB. They remind me of the UN troops on the news. All Talk and no Walk. They didn't even post my complaint in their records. On to the FARCE called the Dept. of Consumer Affairs for the State of Florida. Same results, (wasted postage) just like the BBB. Bottom line is in this instance, the "THIEF" (company name available upon request) is currently under investigation for the murder of his daughters' mother. What one sows , One reaps....Hmmmmm...Now wouldn't that be nice....
  • buickman2buickman2 Member Posts: 6
    We all see the hourly rates, in most states they are posted. They just keep going up and the level of our car care keeps going down. When I go to the Mercedes dealer they charge more per hour than my Doctor does for an office call. ?????
    And half the time I think they turn the "lot boy" loose on most of the jobs.
    What ever happened to the old flat rate book ?????
    Have you noticed when having any work done on a new car still under warranty, that you never see the cost. With GM you just sign for the work done. They dont want you to see what they charge the factory. Nor do they want to scare you off from coming back after your car is out of warranty.
  • 0patience0patience Member Posts: 1,712
    They still use the flat rate times when they charge you for repairs.The dealer charges the same flat rate times to the manufacturer,but at a different shop rate.What warranty times would you like?My personal opinion,if the vehicle is outof warranty,shy away from the dealer.I've seen shop rates from $48-$89/hour.Don't pick a shop on rates alone.
  • md_techmd_tech Member Posts: 84
    Are dealership charges flat rate times from Chilton's big book of flat rate hours per job.... The dealers are hurting because of all these Independent Shops coming up with better prices. The dealers are running specials and offering discounts because business can go elsewhere... Although, the hourly rate that they charge keeps going up....A lot of consumers believe the techs. are making all that money but that's not entirely true most of the money goes to the dealer.... not only does the dealer get all the money between warranty and fee's we have to buy are own tools, which the price for those items aren't going down either!!!!
    Kristina/co host Our Turn
    It kills me when I hear people say that the mechanic is charging them too much money.Too bad the mechanics don't get more of the shop fee.
  • tboner1965tboner1965 Member Posts: 647
    I've got a question? Who pays for the factory training? Don't techs get trained at factory schools? Is it the dealer, the manf. or the tech that has to pay for that? If the dealer sends you to a course, are you still drawing a wage while in training?
    If the dealer pays for it, it somewhat justfies (perhaps not entirely) the fact that they are keeping a good portion of the labor rates. We had this same issue in computer training. We'd spend 3-6 months salary to get an instructor trained before we could even turn that instructor loose on a solo taught class (one instructor leading the class) and this doesn't count the travel costs to send that person probably twice a month to take or even co-teach classes in other cities. It could easily cost us $9K-$18K in travel plus $15K-30K in salary and benefits before that person made us a single dime. Imagine putting a $24K-$50K bet on a new employee. (Salaries are much better in technical training than teaching in your local public school, but you have to travel and you don't get summers off.)
    My point is, that your dealer probably has some money invested in you and the shop your work in, and should be entitled to recoup that.
    I do think that the tech's seeing the labor rates probably does not help motivate them. Most probably think they are being screwed. (And I'm sure some if not many are.)
    If you are truely motivated, open your own shop. Then you can keep more of that labor $$$.
    Not a rant, just another perspective on this subject.
    Cheers,
    TB
    When I worked in a retail shop,then shop did pay for the training,but the time was on the mechanic.And at fairly low wages.I have worked for fleet shops the last 14 years,plus do fleet work in my shop at home.The fleet I currently work for pays for the training and the wages for the time.There is no reason a Dealer can't pay for the time and the training,but most do not and they pay their mechanic's poor wages.One dealer that my shop has to deal with,the mechanics are paid $10.50/hour.Personally,I think that is a very poor wage for a person who has thousands of dollars invested in tools.The average auto mechanic has around $8,000 invested in his/her tools.They do not get any compensation form their employer for the cost of those tools,either.So,people,please give the mechanics you deal with,a little consideration.Most of them are honest hard working people who are trying to do the best with what is supplied to them.
    Yes the dealer does pay for the courses we have to take to update are selves on the new and improved product they put out. We don't fly to some exotic island we have a training shop over in Virginia in which we drive are vehicles. An your correct they do pay us for the day a whole 8 hours we could have made twice that in two hours,but education is more important than what we could of made for the day. The education we receive helps us deal with problems we might run across. An going to school dosen't happen right away you have to be working with the company for almost a year before you can even get a chance to be enrolled...
    Yes, owning my own shop would be like a dream come true... But at the moment I put in enough hours at work and not enough time or energy at home with my 5 month old son!!!!It's not always just the pay it's the time and money invested in the field.
    It's getting warranty claims that take 4 hours to do and only get paid 1.6 hours... Don't get me wrong I'm in this field because I truly love working on cars. I love knowing that the mother taking her kids home has a safer vehicle because of my knowledge and skill to fix that vehicle...
    It's just I'm sick of good techs. getting a bad reputation. Like I said before we don't make all the money..... Sometimes the only thing I come home with at the end of a long day are metal splinters,scrapes,and sore feet but I don't expect the consumer to feel sorry for me...I'm not trying to rake consumers over the coals for the jobs I do but, that dosen't mean the dealer won't!!!
    I understand that the dealer gets a good chunk of the labor dollar. However, I think the customer has a right to expect a quality job.
    Recently while reading at www.contour.org a particpant took his vehicle in for a check engine light. He was sold a bunch of repairs and sure enough, his check engine light was not lighting up any more, ever. It seems someone at the dealer removed the light.
    I'm not saying a tech did this, but the customer should receive a quality repair, and not just treatment of the "symptoms."
    Oh, and I understand the busted knucles, scrapes and splinters. Spent the better part of this afternoon changing the rear struts on my 1987 Buick. Don't laugh, I spent about 20 minutes trying to get my hubcap off. Then I found out what that strange wrench in the glove box was for. Fortunately, I only buggered up one, but not too bad.
    Tomorrow it is the fronts, then Monday, off to my mechanic for alignment and wheel balance.
    Cheers,
    TB
    Whoever worked on that persons car should't be working on vehicles!!!! I bet your getting a better ride after you installed your struts... I've never done rear struts on a Buick. Are they difficult????
    The rears were easy, gave up on the fronts as I couldn't get the spring compressor to cooperate. So I'll have my shop finish the job. At least I got the bolts all nice and loose for them, as well as cracking the code on the hubcaps.
    After getting the whole thing together and hopping in the shower, I had the thought that I could have taken the strut with spring down to the shop and had them replace the units, but I'd still need to return for a four wheel alignment, so I'll just make one trip. At least I'll know they have the parts :)
    I couldn't do this for a living, but it is good therapy to bang and grunt and tug on the cars during the weekends. That is what makes it fun, I don't have to do it, only do it when I want to.
    Cheers,
    TB
    Only having to do certain jobs when you feel like doing them. Working on cars is my way to release frustrations of day to day life... Until next time tboner1965.
  • joeg26erjoeg26er Member Posts: 10
    I took my 1987 Honda Accord DX Hatch 5spd into a Meineke shop for a slight clunk noise on the left.
    They said the left CV axle was bent put one in.
    I should have known better when they bumbled around trying to figure out what kind of transmission oil it took and where to put it in...
    Drove home and parked over night-
    In the morning I noticed a small pool of oil under the vehicle! It had NEVER leaked before!
    I called them up and they said to bring it in later. They said it was probably the seal.
    They replaced the seal three times - the second time they did that I asked them if they had the wrong axle -
    "No Way" they said...it still leaked and I had to travel a couple thousand miles with it leaking before I could get it back to them for the...fourth time!
    The trans was making a high pitched noise probably from lack of oil when I pulled in for the fourth time in their shop!
    Long story short - it WAS the wrong part!!!
    It was an axle for an automatic trans Honda, not a standard!!! Idiots!
    They pulled that axle a total of THREE times without checking to make sure it was the right part! Even after they put the right part in it continued to leak a bit because they had rounded off the trans oil plug and refused to buy a new one!
    Don't go to Meineke in Jacksonville, FL in the Regency area off of Philips Highway!!!
    Not my favorite place to get a car fixed!
