Stories of INCOMPETENT MECHANICS - post yours!
124»
  • wilcoxwilcox Member Posts: 582
    I've got about three little stories that have three National providers (chains). The first one goes like this...happened many years ago, and may not occur today(according to their most recent ads):
    I decide that the transmission needs a fluid change and "checkout". Take it to their service facility. When I come to pick up, a person is there to tell me that they found metal shavings in the bottom of the pan. Recommend a new rebuilt unit be installed. I choose not to have the work performed. I continue to drive the car for many years without any "event".
    This has happened to me twice. I have only traded with this chain twice. It has taught me that, sadly, the franchise(who specializes) seems to be eager to perform jobs that may not be required. It has also taught me that my gut feelings have a high percentage of "correctness".
    This is not isolated to automobiles, I see this in alot in different specialized services.
    tboner1965: Your suggestions could make for a great research project. I wish that I had the time and a place to publish something so intriguing!
    sugardog: I'm finding that I must stay in touch with my car just as much as possible. I've bought a real good jack. Good car ramps. Tools galore (comein handy everywhere). Books. Visit places like this. Etc. I'm tired of incompetence. I'm trying to do alot myself. If I screw up then...I screw up and learn somemore things. Good luck.
    You did a great job of not naming names. I know EXACTLY who you are talking about.
    " There are metal filings in your pan...you need a transmission overhaul"
    sugardog,
    It's also easy to get too cynical. Most shops are honest and honest shops get problems blamed on them everyday that they didn't cause.
    " My transmission never leaked until you worked on my brakes...you must have done something!"
    Ask any honest repair shop about this. Most shops will decline working on a customer's car if they suspect they are dealing with a person like that.
  • CooperCooper Member Posts: 55
    Seeing the posting about the transmissions reminded me of a story ...
    Years ago, a friend brought his car into a national retailer. The car had difficulty going above 50. The shop diagnosed the problem, and wanted to replace the transmission ... for somewhat over $1,000.
    Being poor graduate students in the early 1980s, living on an annual stipend of $6,400 a year, $1000-plus is a lot of money. Knowing I worked on cars some, my friend asked me what to do.
    So, before agreeing to the work, we brought the car to another shop.
    The mechanic drove around the block with us, and concluded, "I'm not sure exactly what it is. But, there is one thing I can tell you: It definitely is not your transmission." He thought that the car might not be breathing well. He asked that we drive the car up the road to his friend at a local garage, and ask that he back off the exhaust manifold bolts.
    As soon as he loosened the bolts, the car started running great. As it was a high mileage car, the catalytic converter had collapsed, and the engine could not pass the exhaust. All it needed was a replacement converter.
    So, here's an example of both the "good" and the "bad." I guess that makes my friend and me the "ugly."
  • mmcbride1mmcbride1 Member Posts: 861
    Maybe it's just me, but when someone is shady like that, you SHOULD name names. How can others avoid them if they don't know who to avoid?
    It was many years ago when I used that National Transmission outfit. Their most recent ads say that in many cases, their clients don't need new trannies.... So, like maybe they have changed...maybe they have not... No matter what, if your auto trans pan has a few shavings of metal in the pan, then that is normal (provided that it is performing normally). Need $200K? I thought you had that....and more!
    I've got $200, it's the K part that gets me. That is one awesome car, though.
    This has been a good year for cars. Better than in the past. Cars require less service...oil, grease, brakes, radiator, etc.
    Yet, there is atleast one service provider out there who likes to send you some book cupons. Oil change, $6.95, "Free" safety inspection, Brakes, $39.95*, Tirerotation, A/C tuneup....you know the hype.
    Every time that I have used this one "national" tire chain store,...everytime..., half-way thru the service they contact me with "Mr Wil., there is something that we need to show you...". They always seem to cook-up more business. And, their 'extra work' is absolutely sky-high!
    Now, seeing how they have your vehicle up on the rack, they want you to make a split second decision...and...if you answer no, they can quickly tell you all the terrible things that will happen to you if you don't buy it right NOW! No telling how many people fall for this stuff....
    If they come to you with the bit about "lookie here"...I suggest that you make them do the estimate and then say no thanks. Take the estimate and go shopping elswhere...save about half....easy....they'll burn you a new one if you let em.
    Went down to America's favorite retailer and signed up for the "premium" oil change. It included oil, filter, check fluids & pressures, vacuum, blah, blah..
    Went in shopping and returned to pick-up. They were pretty quick, car was ready in an hour and fifteen minutes.
    Invoice read 6 quarts of oil. I said "..car only holds 5 quarts...". Clerk/tech said, "..don't worry it's alright...just the computer print, happens all the time...". I go out and check the level. Too much oil according to dip stick. A quart too much! Also, they had forgot(neglicted) to perform check and vac. services.
    I've changed my oil ever since. Tired of relying on other providers whose "help" changes monthly. Like to save money and time. I enjoy changing the oil. I take my used oil over to their place and leave it there for them.....haha...and have the satisfaction knowing that service was done "right".
    Most anyone who has a "place" can do this....
    wil
  • 0patience0patience Member Posts: 1,712
    If you do a research and review on what tbone was talking about, I will provide you a place to put it and give you the credit on the page,I might actually be able to get it on 2 automotive sites,one for sure.So if you do get it researched and written up,let me know.Myself and several other mechanics are working on review pages(that time thing you were talking about keeps getting in the way) and if someone writes a review,I don't see why we can't put it up,as long as it isn't out of line.
    Have fun.
    your post gives me even more incentive to retire early and begin my "self-actualization" program...
    And thanks for some of your informative posts, observations, and ideas here in the Maintenance Topics...I have enjoyed them.
    wil
  • oldharryoldharry Member Posts: 413
    I heard those ads from that chain. They say half the customers don't NEED a new tranny, but they don't say that they don't try to sell one anyway. The Chicgo Tribune got them about 25 years ago, the Olds they drove around to a dozen of those shops with the vacuum modulator hose pulled off so it wouldn't shift got eleven (if my memory still works) new trannies in one week.
    Harry
    I think I'd trade with you if you were in my town...
  • casper11casper11 Member Posts: 1
    A ford dealer in arizona tell's me I have a blown engine only to find out a week later it's a bad catalytic converter. Oh yeh I only have 25000 miles on the car. The dealer's name is Berge ford.
    How did they come to that conclusion?What diagnostics did they charge you for?
    I'll bet there was smoke coming out of the air cleaner box when you were trying to start it?
    About 70% of no starts that are seen,that just happen are caused by either a plugged fuel filter or a plugged catalytic converter.But,I hate to give you bad news.If the catalytic converter plugged at 25,000 miles,you have another problem and if it does not get squared away,you will have another plugged cat in another 25,000 miles.You either have a rich running condition or a spark problem.Something to think about.
  • michaelsolomonmichaelsolomon Member Posts: 7
    Over a period of 25 years,I have had my cars to many different shops,some good some bad.But also, I have talked to many people in the business and also worked in repair during the 80's.After that,i went into hd truck parts,semi's and trailers.Over the years I have found 3 reliable repair places.One for major stuff,onr for oil changes and one for suspension and exhaust.It pays to have someone that knows what they are doing.My worst story-we had a 1982 Monte Carlo which needed rear springs.when I picked it up, the rear was 12 inches higher.I went back in and it turns out they put Caprice coil springs in!
    a while back I had my head where the sun doesn't shine and described a Tempo suspension for your Contour problem, but the principal was still right. Recently I saw a reprint of a Ford service bulletin on the hi-performance Contour concerning "pull" to he right. They said to loosen the engine cradle bolts, shift the whole assembly to the right, then push the right side rail forward. This increases left camber, decreases right camber, and increases right caster. Each by itself would increase the tendency of the car to go more to the left, or less to the right. I hope you ot yours fixed.
    Harry
  • luckymomluckymom Member Posts: 5
    Well, it's been a LONG time since I posted about the Monte Carlo (see #59). We finally made it thru the lemon law- That car is out of here! We're getting back all but about $2000 (for the milage). It sat at the dealership for about 6 months. Even today they said thy couldn't find anything wrong with it (until the decision was reached). Now, they're going to tear it down and fix it- so they can resell it.
    I've learned a lot over the course of this mess- #1 it's not the local dealership that was our problem, it was the GM rep who wouldn't authorize anything to be done. #2 The BBB everyone goes thru is a crock. They work for the manufacturer. They're paid for by them. The object is to wear you down with the whole process. #3 Document everything!
    Yes,documentation is everything.
    Keep all repair orders,make them put the complaint in writing on the repair orders and keep all copies.If you have a problem,get names of the people you talked to on phone calls to them and the manufacturer and log all of the calls.Some people think this is a little extreme,but it is in your best interest.
  • arjay1arjay1 Member Posts: 172
    In 1987 or 1988 I purchased a new Hyundai Excel (don't laugh!) It had a grind that could be felt in the shifter when going from 1st to 2nd when the car was cold. It took a lot of trips to the dealer and leaving the car overnight so they could drive it cold. The dealer was good and always gave me a loaner. Finally after not appearing to get anywhere I wrote a letter to their regional office quoting the Missouri Lemon Law. They responded quickly and decided to put a new transmission in the car out of a new car at the dealer. They said they would then send the car that had my old transmission in it to Hyundai for testing. By this time my car had about 10,000 miles on it.
    The new transmission worked fine for me and the problem was solved. On a later trip to the dealer I was chatting with the Service Manager and asked if they determined the problem with the transmission they took out of my car. I could not believe what he said. "The person who bought the car with your transmission has not had any complaints". They sold that new car that had my 10,000 mile transmission to someone as a new car. Unbelievable!
  • redskin24redskin24 Member Posts: 46
    Monro!
    while getting my car inspected, they found that i needed rear brakes, along with "brake hardware" and a drum turning. i refused the service and decided to have my girlfriends dad fix it. Sure enough i needed new brake shoes. but! only one on one side was damaged. If that one wasnt damaged, the brakes could have passed for new. i didnt need any other hardware, and the drums still had the lubricant on them from the previous turning. Luckily im only 7 bucks in the hole instead of Monro's $100+. They also gave me a $300+ estimate for new pipes from the converter back. that is somewhat reasonable, considering i have dual exhaust and single exhaust for my other car cost $130
  • guitarzanguitarzan Member Posts: 873
    Brake places are notorious for this. They will not just replace something that is worn, they will only replace the entire system. They claim this is for "safety". I can see this only to a point: You ask for new shoes, and come back a month later after right rear brake fails, due to overheating because the caliper stuck or something similar. But brakes are overall so reliable, that standard maintenance, like periodic caliper lubes, will keep them working fine. Instead, they want to replace all the hardware on every visit. What a scam! I would recommend that people learn to do their own brakes, like I have. However, with anti-lock brake systems, the potential for damage is so huge, I consider that too big a risk.
    as a rule, if you change one side, you have to change the other. but not necessarily the hardware, it may just be the pads/shoes.
  • wtdwtd Member Posts: 96
    Recently I took my 98 chevy ext-cab 4x4 to the dealer to have them look at a few things and i decided to have them rotate my tires since they were due. The service adviser and I were talking about why my front tires were wearing so bad on the outside edges and he was looking at them. He asks me how the tires were being rotated and I told him. He says thats wrong, so we look in the owners manual and we are both wrong. Its supposed to be: back tires straight up to front and front tires crisscrossed to the back. While the guy is rotating the tires I go out to ask him a question and notice he is rotating them the exact opposite of what the owners manual says. I go tell service adviser and he goes out to the garage. The guy says he is doing it right and my adviser comes back and says he is doing it right. I say okay, maybe I remembered it wrong in the manual. The truck gets done and I look in the manual and sure enough they had done it the exact opposite. I show the adviser that the most worn tire we had been looking at on the passenger front was now on the passenger rear. He then claims he doesn't remember which tire it was and still says his guy had done it right. I than ask him why my tire that had been on my RR which I knew didn't have a wheel weight on it, was now on my LF. He doesn't know and still claims that it was done right. He finally offers to do it again but I say forget it because I didn't have time. Because of all of the tire wearing problems I was having, I knew which tires and wheels were where on the truck and he still acted like I was an idiot and that the job had been done right. Since they don't know how to do a tire rotation right, I guess I can't trust them to do anything harder.
  • bettyd1bettyd1 Member Posts: 5
    I bought a 2000 Winstar in March and took it into the the dealership for it's 2nd oil change and to have a few things checked out. Aside from one of the power doors not working I asked them to check the engine, because it was loud and getting louder.
    When I called to see when to pick up the car and find out if all had been done. When I asked about the noisy engine, the service guy (Mike) said it was normal and the Winstar has a loud engine. When I said it was getting louder and didn't seem right, he dismissed my concern and said it was normal and not to worry about it.
    I picked up the car and over the next couple of days noticed a strong oil smell. I called the service dept. and was told it was probably grease, because they had to fix the power door. When I said it didn't smell like grease I was again told not to worry about it
    Two weeks after having the car serviced it became undrivable and had to be towed to the dealer. Turns out the engine needs to be replaced because of blown gaskets. It is not repairable.
    The treatment I have received from Koon's is deplorable. They said at first that I had to rent a car, and wouldn't give me a loaner. Many calls later they said they would reimbursement me $28/day for a rental and I had to pay the difference(what can you rent for $28/day. I have a van for a reason!!) Finally, many hours and many, many calls later I was told I could have a loaner of a Taurus.
    They never call me even when I am told the service guy will call me right back. I always have to call them and then am given the run around. I was told I would have my van back in a week. A week later, no courtesy call to say it wasn't ready. I had to call repeatedly until Mike told me, after 2 weeks, it is not ready and they don't know when it will be. Today they told me I am on the waiting list for an engine.
    The loaner manager want's the Taurus back and said I could rent a van and they would reimburse me. I said I wasn't paying anything out of my pocket and if they want the Taurus they have to bring me a van that THEY have rented! We are at a stalemate. I am still waiting to hear from them.
    This is no way to do business. This is such a shame, because we are in the market to replace my husband's car and they will never get our business again.
    Sorry this is so long.
    Thankyou so much for the post on "pulling to the right" suspension problem....appreciate it!
    Tire Guide (a publication of the Tire and Rim Association) lists normal rotation patterns as:
    Rear wheel drive and 4X4,
    1 Rears straight forward, cross the fronts to the back.
    2 X the tires
    Front drive,
    Fronts straight back, cross the rears to the front.
    All vehicles,
    Front to rear, rear to front, same side.
    Shops often use rear drive pattern on front drive or front drive pattern on rear drive if it will correct an unusual wear pattern on tread.
    Harry
  • nateatvtcnateatvtc Member Posts: 2
    Well, it all started with a defroster switch. About a month ago the face plate that holds my defroster on the dash broke. As my car was near the end of the 36k warranty I decided that I should get it fixed. I brought it into the dealership and had them look at a few other things while I was there. They said that I would have to order the part and would call me. A couple of days later I received a call saying that the part was in so I drove down to the dealership to get it. At that time I asked if I could pick it up and put it in myself, to which they responded that since it was warranty work that they had to install it, which was all good, I just wanted to skip the wait. Well, they got out the part and then realized that it was not the right one, so they had to reorder. A few day later they called and said that the right one was in. So I went down on a Friday to see if they could put it in but they said that I needed an appointment so since the only day that I could do it was on a Friday, I re scheduled for a week later. Friday rolled around and I brought the car in. I parked the car in the garage and went into the waiting room. After 15 mins of waiting I went to check and see if it was done (it was only about a 30 second job). Of course my car had not moved from where I had parked it so I headed back to the waiting area, but as I was on my way there I heard a revving engine, squealing tires and a loud crash...... humm, my car was the only one in that waiting area... well, I went back to check to see what had happened... my car was not where I left it, I was now parked through the garage door. WONDERFUL!!! It appeared as if the technician had started the car with his foot on the gas and when it fired up it scared him so he dumped the clutch... Have you ever seen a Neon lay 20' of rubber... well, now mine has the claim to fame. So anyway, my car went through the door and hit another car on the way out. There was damage of one sort or another on all but two panels on the car. The worst of the damage being the roof getting pretty well dented in and the front drivers side pretty well crumpled. Well, needless to say, I was in shock for a while. After things got sorted out they set me up with a rental which was nice but I had no clue what was going on with my car. I took mine for a quick test drive to make sure the transmission was intact and also to get an estimate from a garage down the road. After about 10 mins. it came though at $5,900 (on a $6,500 car). So I brought it back to the place that wrecked it and gave them the estimate. After looking at the estimate I was told that I could bring my car anywhere I wanted to but I have to use their parts and that the insurance company didn't use the labor rates that had been used on the estimate. I have talked to multiple insurance people and they said this is bogus. Anyway, they said that they would have the appraiser in there on Monday. Well, Tuesday rolled around and no word so I gave them a call. Apparently the appraiser hadn't shown up but he would be there soon... good enough I thought. Thursday rolls around, no word... I gave them a call again... the appraiser just left and would have something to them Friday - Monday at the latest. Well, today is Monday so I gave them a call... guess what, no word from the appraiser yet and when I asked if I could get his name and number the guy told me just to call back tomorrow. I am starting to get a little upset. I was very patient at first. Now I do realize that it is the appraiser that is slowing this whole thing up but if I was them I would be after him to try to get this straightened out. At this point I'm not going to disclose the name of the place but if I call tomorrow and I get the same thing then I think that it will be time to get a little more vocal. I probabally will get my insurance company involved. I can just see this outfit trying to screw me. They will come back with an estimate for 2k less than the one that I got.... what a pain. Oh well, in the mean time I am putting as many miles as possible on the rental and beating the piss out of it. Hope it all works out in the end... this is probabally the most expensive defroster switch that they have ever put it.
