Back up Light Switch location
generomgenerom Member Posts: 2
edited December 2015 in Ford
Back up Light switch does not work. Would like to replace it. Where is it located? Thank You
  • thecardoc3thecardoc3 Member Posts: 5,863
    The switch is on top of the transaxle, it is an input to the SJB (smart junction box) which controls the lamps with a relay.
    Diagnosing that circuit should be done with a scan tool that can display the SJB data and also command it to operate the relay with bi-directional controls.
