Awkward Conversations - 2015 Acura TLX SH-AWD Long-Term Road Test
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
The problem is real: Edmunds' long-term 2015 Acura TLX SH-AWD with the 3.5 V6 is plagued with a poorly calibrated nine-speed automatic transmission.
http://www.nastf.org/i4a/pages/index.cfm?pageid=3823
You will need a compatible pass through device of which some will be able to be used for this same purpose with a number of manufacturers. This is the Honda pass through tool.
https://honda.snapon.com/HondaAcura/ItemDetail.aspx?ItemId=53561297
There are some J2534 tools that can run O.E. software, but they are not all created equally so there are risks that must be assumed by the purchaser. The 2015 Acura software "might" run on a CarDAQ Plus.
Once you have the MVCI you can then get a short term subscription for the Acura HDS scan tool. Being that this is somewhat repeatable, you might get away with just the one day subscription. Then, drive the car and capture the data during one or more of these events. Upload screen captures of the data in a graphical format with flags denoting the event. You will need both PCM as well as TCM data if they are separate PID groups.
Then we can let the sleuthing begin and see how the group does when faced with this kind of data.
