Engine Looks Like an Engine - 2016 Mazda MX-5 Miata Convertible Long-Term Road Test
Edmunds.com
You may or may not be surprised to learn that the engine in our 2016 Mazda Miata actually looks like an engine. It's one of the unique elements that makes this Miata a true enthusiast's car.
WTF?!?! They put a heavier steel valve cover instead of the existing plastic solution just for the looks? Instead of saving another couple of pounds of front axle weight? Might as well put an engine cover then if looks govern...
Question -- hows the horn sound? The NC has a horrible clown-car horn. First thing I did to my car was to rip out the stock horn and put some Hella Supertones in there.
longtimelurker, I'm not sure I understand your point. The NA and NB used engines from or based on the 323, so sharing an engine with the Mazda3 is nothing new.
Frankly, I prefer the "bare" look in an engine bay. I like being able to pop the hood and see what's going on with the engine, particularly if I'm having an issue with the vehicle and I'm looking for an obvious problem.
Of course, the Miata has no competition and there is not a lot of incentive for them to offer an upgraded engine...Honda was competing against a Z3 M-Series when they introduced the S2000...which was also rated at 240 hp, not coincidentally. Mazda will sell every 155 hp Miata they make...I understand that...but all the same I would like to see more of a value proposition. And of course any RWD/front-engine design with such a low cg and good F/R weight distribution can handle more power without a lot of problems.
And yes, I understand these cars don't really compete...just showing how the Miata 0-60 figure may be misleading.
