Paddle Versus Pedal - 2016 Chevrolet Volt
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
The 2016 Chevrolet Volt continues the automaker's strange recent habit for assigning unconventional functions to steering wheel paddles.
What happens when you apply the pedal when you have the paddle pulled? I would hope it just reduces regen, allowing you to adjust your decel rate. EDIT: I looked it up: hitting the accelerator disengages the regen.
Put the shifter in "L". I'll bet that's what you want.
In practice, the car automatically regens via the brake pedal anyway so the paddle is a bit of a parlor trick IMHO but there were apparently a number of people who requested a way to engage maximum regeneration without using the brakes at all. I agree that a better implementation might have been a more aggressive L option.
The new Acura NSX implementation of regen braking seems to be a great idea. The brakes on the NSX are actually a brake by wire system. The pedal is not actually connected to the braking system. Like the accelerator it is merely a sensor for the computer. When you press the brake pedal the computer mixes regenerative deceleration with actual braking. Dip in the brakes and the computer may provide maximum regenerative deceleration but no actual brakes. Need maximum braking power and the computer will give you maximum bite from the brakes and maximum regenerative deceleration. From the driver's seat it just feels like braking.
I'm not sure how slowing down will help you get to your destination...
- brake pedal: invokes regen under light load and until the speed drops, then blends in normal braking. you really have to pay close attention to notice the difference.
- regen paddle: this lets you full regen at will. its useful as you approach a stop.
- "L" mode in the "transmission": this adds automatic light regen as you let up on the accelerator. its gives you a little of the one-peddle drive mode. would be nice to be able to select a more agressive regen mode here.
