Love the Capless Fuel Filler - 2016 Honda Pilot Long-Term Road Test
 Edmunds.com
Edmunds.com
What does our long-term 2016 Honda Pilot have in common with our long-term Ford Mustang GT?
1
On an ancillary note, I actually miss the centrally located "behind the license plate" fuel filler. Sure, you ran the risk of the car exploding upon impact from being rear-ended. But come on, you're not going to live forever. Plus, it was equal distance from the pump, not matter which side was facing the pump. As it is, half the time I pull in with the wrong side of the vehicle by the pump. And since they're both trucks, I'm not doing the "I'll drag the hose around" routine.
Thanks for letting us know about it. One learns new things every day !
My wife's Subaru Forester has the filler on the passenger side.and my Toyota and Hyundai on the left side .
Now that I'm in my 60s, I've found that it also helps to cut back to one car.
It's a minor niggle, but one to consider nonetheless.
No more broken tethers. If you want to add fuel system cleaner or preservative, just use the adapter(basically a proprietary funnel).
Gas Tanks: Why Aren’t All Fuel Doors on the Same Side? (allstate.com)
All the other theories sound good (although some seem a bit urban legendish too me), but as always, follow the money. My gut tells me the tank will go on the side that's cheapest to manufacture, at least in the US where no regs require placement on the left or right side. That decision may be influenced by where the exhaust goes or for other safety reasons, but it it's cheaper to put it on the right, that's where the filler will go.
