Fuel Economy Update for December — Early Disappointment - 2016 Honda Pilot Long-Term Road Test
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
December ended quietly and unimpressively for our 2016 Honda Pilot, especially from a fuel economy standpoint.
Yes, I hate this, too. But it is easy to ask them not to do this. Just open your mouth and say "no top up, please." It works.
Also, there is absolutely no way this kind of vehicle will achieve 26 mpg driven normally. Maybe if you drive at a steady 50 mph on level roads.
In one instance, I politely told the sales manager that they are making them everyday, so please stop with the business of demand exceeding supply and your his offer of a minimal discount. From what I can see, the lots have a very good supply. Typical, but not unexpected, behavior of Honda sales staff whenever there is a new release. I've owned 4 Hondas over the years and the worst buying experience I had was with my 2001 Odyssey.
My experience has shown that the van does GREAT when its variable cylinder management system is able to stay on 3 or 4 cylinders. Generally speaking that means driving on mostly flat roads, or roads with very slow inclines, and staying under 75 mph or even under 70 mph if driving into a head wind or with the A/C cranked up. In these conditions the van can manage 30-32 mpg!
However if you go up to 80 mph and/or drive on highways with lots of ups and downs, you might be lucky to even get 21-22 mpg. The hills cause a double-whammy to MPG, because on the way up the hill, the VCM can't stay on, and the car may even have to down shift. Then going back down the hill, if the cruise control is enabled and the hill is steep enough in decent to cause the car to exceed its set speed, the transmission will downshift to slow the van down, which of course kills fuel economy too.
I really wish they would put a 'economy cruise' mode on the Odyssey (and pilot), which I would envision to keep VCM on if at all possible... not kicking out of VCM mode unless my set cruise speed is at least 10mph over the speed the van is able to maintain. That way on the way up a hill, the car will bleed some speed but stay in VCM (maintaining as much speed as it can on 3 or 4 cylinders), and on the way down the hill, it won't feel the need to downshift and slow the car down because it will have extra speed it needs to gain to get back to my set speed.
I know this would make a HUGE difference because if I go to the effort of manually controlling the throttle on the highway, and carefully only pushing far enough down to not come out of VCM mode, I end up getting 30+ mpg on those same hilly roads that cruise control only gets 22 mpg from.
Put one person in it, with no cargo, & then see how it does.
However, it seems like most people on the forum are getting better mileage than that. Lots of complaints on the 9 speed auto though although people say it smooths out as it learns your driving and you get a few miles on it, not good for a car that changes drivers a bunch so it will be interesting to see if anybody ends up liking this transmission at Edmunds.
But going that fast and the slog up I5 into Oregon has a lot of uphill run to it, I'd say with a full load and for the Honda 3.5 its probably not that bad. I think everyone needs to keep in mind that EPA ratings are best case scenario... 4 people and full of luggage easily adds almost a 1k lbs of payload!
Normal load - recent round-trip from Phoenix to Flagstaff and back (same day, same road & weather conditions) ...
Normal load = 2 adults, 4 children, 100lbs. of cargo ... ~700lbs. total.
Phoenix to Flagstaff - 21.2 mpg (mostly uphill)
Flagstaff to Phoenix - 27.5 mpg (mostly downhill)
Wind conditions ... 30 mph, West-to-East crosswind, with a slight southeasterly kick. This hurt slightly going to Flagstaff and helped slightly returning to Phoenix.
Our combined mileage on city freeways & surface streets is 23.2 mpg. We have 1500 miles on our new Pilot so far. I know that's not a lot of miles to base my opinion on; however, I am basically getting exactly what the manufacturer numbers purport ... and quite happy and impressed thus far. I am fortunate to get 24mpg combined with my 2007 CRV EX AWD, with 150K on it.
The 9 Speed Automatic is getting terrible reviews on both this Pilot and your long term #Acura #TLX.
2001 Prelude Type SH, 2022 Highlander XLE AWD, 2022 Wrangler Sahara 4Xe, 2023 Toyota Tacoma SR 4WD
With all that said I think the Pilot did pretty good considering the engine is still green, and it was loaded with 4 people and all of their luggage on board.
7500 miles ... lifetime fuel efficiency thus far, 21 MPG combined. We've seen 26-27 MPG on a couple of tank fulls where the round-trip was light and flat.
Camping Trip #1: Approximately 300 miles round-trip. Very few elevation changes. 17.5 MPG round-trip. The Pilot pulled our 3500lb tent trailer with ease.
Camping Trip #2: Approximately 240 miles round-trip. Several elevation changes. 14.5 MPG round-trip. Again the Pilot shined and never had any problems achieving posted speed-limits. Steep inclines were limited to about 55mph (without over-revving the engine) ... but that was fine for the task at hand / posted speed limits.
My major complaint about the Pilot's towing abilities are the really soft rear suspension. The towing capacity tongue-weight rating is a little to generous IMHO, unless you're going to use a weight distribution hitch or find away to install air bags on the rear axle. Because towing weight and tongue weight is generally a 10 to 1 ratio (tongue weight = 10% of trailer weight), I would probably not recommend towing anything over 3000lb without a weight distribution hitch or modification to the Pilot's rear suspension (e.g. air bags or stiffer shocks/springs).
Camping Trip #2 included a really chunked-up, two-track getting into the campground. Because of the rear sag, my pop-up trailer's slide-out step (for entering the camper once parked) was bent, and one of the rear plastic mud "flaps" on the Pilot took a lickin' too.
I actually just decided to buy another truck, so that will probably assume the towing needs of our household.
