Slow and Steady - 2014 Ram 1500 EcoDiesel Long-Term Road Test
Edmunds.com
Thanks to the 2014 Ram 1500 pickup's onboard computer, drivers know exactly how long they've been sitting in traffic.
Between the traffic and real estate prices it sounds like SoCal has enough daily stress to completely eclipse the nice weather and coastline. Assuming you can ever get to the coastline at 21 mph.
So my thought is this...if you go to a larger diameter tire, the circumference is larger. This means you travel a longer distance than the you would with the stock tire, per revolution. So if you have a stock tire that travels 100 inches, per revolution, then go to a larger tire that travels 115 inches, per revolution, you are getting a greater distance with the same RPM, an increase of 15%. You would think this would equate to a higher MPG (fuel economy) due to a drop in engine RPM or the same MPG (fuel economy) at a higher speed. However, real world data does not support this.
Anyone willing to bite the bullet and help me understand why?
@tlangness
@5vzfe
@whoever else is trying to help me:
Thanks for the help guys. It's like I said...I KNOW it doesn't work the way I said in my mind I feel it should work. Some day, when I am ultra rich and can burn money faster than the Federal Government [non-permissible content removed] I'm going to buy two identical vehicles and start playing around with it until I can understand it by visual comparisons. I told y'all y'all would read the posts and think "what an idiot." It's one of those things that you know, but you keep trying to disprove yourself on.
It's the same thing here. Adding bigger diameter tires is just like going up a hill; to maintain a given RPM in any gear the engine requires more power. More power requires more fuel.
Poor aerodynamics has the same effect, it take more power to push through the air, more power = more fuel.
Pretty much anything that requires an engine to use additional force to maintain a given speed in a given gear will reduce fuel economy.
GM is way behind Ford and even Ram with innovative powertrains for their trucks but that ancient 5.3 pushrod V8 and 6 speed auto seems to be the best compromise for fuel economy and power. It doesn't pull as hard as the Ecoboost engines and doesn't get the fuel mileage of the EcoDiesel but it's in that sweet spot in the middle of both. If I was buying a Ram I would get the 5.7 Hemi with the 8-speed auto. Real world fuel economy and capability is about the same as Ford's EcoBoost engines and it's cheaper to buy and maintain than the EcoDiesel.
Not convinced that there is going to be all that huge a cost delta since the GM dealers seem to be planning to hold MSRP on the little diesels (and they easily crack 40k) while careful shopping can yield pretty substantial discounts on the Rams. If you don't need to have leather or nav, a low to mid forties sale price on a reasonably equipped CC 4x4 is in reach, with the difference of perhaps a few grand representing tangible value in the form of that roomy cab and a wider cargo bed for me. An Ecoboost F-150 has the cab and the towing, too, but every test I have seen indicates that the V6 EB engines are more boost than Eco, so the Ford fails my fuel economy metric... and yeah, I know all the diesel cost arguments, but here in SoCal diesel is cheaper than regular and has been for some time. I understand that this varies, but the tradeoffs work for me since I value the torque and altitude performance of the diesels.
The Ram 1500 with the 3.0 fills the bill for me, though I REALLY wish you could get a locking differential on the Ram. I spend some time on soft dirt tracks leading to pretty places and a limited slip isn't much help in those conditions compared to a true locker. That's a demerit for the Ram vs all the other candidates I am considering. I also wish they were quicker, but most of my use will be long range trips and I have learned to curb my inner racer as the years have passed. Also, after test driving, they feel quicker than they are because they come off the line briskly with all that low end torque, so they don't feel quite as sluggy as the numbers seem to indicate. In the overall tradeoff study, I think the Ram 1500 Ecodiesel gives me the best balance of my capability needs, and I'm probably going to get one later this year.
Different tools for different jobs. We each define our personal needs and inevitably these wind up giving us different personal decision algorithms, right? I think we may be seeing a bit of a golden age with the current crop of light duty pickups - I fear the more stringent CAFE regs on the horizon are going to start to narrow the choices available to us very soon. I'm jazzed to have as many good options as we see right now, and this finally looks like the year to jump on my downsized tow vehicle and retire my old faithful 3/4 ton gas hog.
Big thanks to Edmunds for extending this road test, BTW. I keep my trucks a LONG time and hugely appreciate a longer view!
