2015 Dodge Viper GT Long-Term Road Test | Edmunds.com
Edmunds.com
Its knock-prone nature is a little puzzling. It's not as though the big, lazy V10 is some highly-strung engine. On the contrary, the Viper's engine is relatively under-stressed as performance cars go.
Let me get this straight: You guys KNEW the car is pinging and yet nobody can even conceive of taking in to the dealer to have a look?
Take it to the dealer before another staffer cycles through it, puts his foot into it a couple of times and knocks a hole in a piston.
but other cars don't ping, so this one shouldn't either. My FCA Wrangler with the 3.6 engine pings on the recommended 87, so I use 89 and it's ok. The Viper, another FCA car, pings on 91 so it may imply that, like my Wrangler, in CA it needs an octane grade higher..
IIRC from the book, the GenV development phase wasn't able to get the knock detection nailed down at all RPMs because of extra time tuning the variable cam timing. If it had, it would have been able to avoid the gas guzzler tax through better emissions and fuel economy.
I think it's something to do with the ignition system being weak around the midrange RPMs at peak load.
In CA ALL in ground gasoline storage tanks must be double walled (since 1998) or the station was not allowed to sell gasoline. This put a lot of the "Mom and Pop" stations out of business. There is also a UST testing schedule that must be adhered to in order to be certified to sell fuel.
I have not heard an engine ping in 25 plus years. A modern car like the Viper should be able to run on 87 without pinging unless there is a problem....
Well, let me modify that slightly: It happened to every car I owned until I started using 91 or at least 89 octane by default, about six years ago.
For reference, all of the above has taken place in California.
