Keyless, Pointless - 2015 BMW M235i Convertible Long-Term Road Test
Edmunds.com
Offering keyless ignition without keyless entry defeats the purpose, as our 2015 BMW M235i demonstrates.
What irks me more, sometimes, is manufacturers using ugly, low quality materials in lower priced models, seemingly on purpose. The plastic steering wheel in my Passat S was terrible.
The whole German thing where you can double the price of the car with options is absolutely insane though. No, I don't want to pay $500 for painted AC ducts. No, I don't want to have to add a $10k package just to get a critical option.
Depreciation is my friend.
I might also mention that another thing that dissuaded me from the GT was the fact that-even with the Performance Pkg.-the car needs the $1500 FRPP Track Handling Pack to make it suitable for HPDEs.
> and in a normal car you'd then have the key in your hand to put into the ignition. But not in the Bimmer...you have your
> [non-permissible content removed] key in your hand and nowhere to put it...except maybe cram it in your pocket when you are already sitting down.
Not sure why you can't insert the key into its slot on the dashboard. This is actually required to start the car if you don't have Comfort Access. I don't mind it. In fact, I would prefer a real key you have to twist.
I currently have two BMWs with Comfort Access and it is nice because BMW makes it perfect, especially on my 550i. I have tried it on some Asian cars and it was not nearly as well implemented, with a physical button you have to push, sometimes only available on the driver's door. I did not like it at all. I like the way the BMW system senses your hand instead of having to push a physical button.You can unlock/lock from any door on either side of the car by simply bringing your hand in close proximity of the door handle..
2016 F23 M235i
