1994 Camry Coupe 2.2L 4cyl
cam6655cam6655 Member Posts: 2
edited February 2016 in Toyota
Passenger side window has stopped working - the regulator was replaced about a year ago and I have tested it directly from the battery and it works up & down; however I thought it unusual to have the drivers side and passenger side window switches to fail at the same time - is there a common relay I should find and replace - I am looking for a common circuit that both switches might travel through to this window motor / Thanks in advance for any help
Answers
  • texasestexases Member Posts: 11,165
    I'd get a voltmeter and see where you stop getting 12V when you push the switch.
    Are you saying the driver window isn't working because of a bad switch?
  • cam6655cam6655 Member Posts: 2
    Thank you for the response, but would it be logical that both switches (drivers side and passenger side) fail at the same time? I was wondering if they both passed through a relay that may have failed rather than either switch? But I do not know if this correct thinking all I know for certain at this time is that the window motor itself is working
    Have you checked the fuse(s)?
