Attempting to Fix the Drone with Dynamat - 2007 Dodge Charger SRT8 Long-Term Road Test
Edmunds.com
Edmunds.com attempts to fix the exhaust drone from its 2007 Dodge Charger SRT8 with Dynamat.
The drone is originating in your two exhaust pipes, and it's entering your car via both air transmission, from the tailpipe, and metal transmission up through the car structure. So even if you Dynamat-ed the entire interior surface of the car and installed double-pane glass, the drone would still transmit up through the structure.
The SRT8 boards say that Zoomers (around $1200) or Corsa (around ($1400) are the most quiet aftermarket units. You have already spent around $150 on Dynamat and tools, and what I have to think is around $250 worth of your labor to install the Dynamat. That is $400 and you are really no closer to solving the issue.
http://www.edmunds.com/dodge/charger/2007/long-term-road-test/2007-dodge-charger-highs-and-lows-of-the-jba-exhaust.html
This is the maker of the exhaust you have on the car. They are located 45 miles from your offices. Why not take the car there, point out the issue and the exposure the issue has on your website and invite them to take a shot at curing it? They designed it; they should be able to come up with a way to deal with the problem...and they might do it for nothing.
And yes, I think there are plenty of LA-area millenial owners of a car like this that could have come up with this idea all by themselves.
These guys should have read this first:
http://www.raamaudio.com/pages/How%2dTo.html
and I'm in no way, shape, or form affiliated with RAAM.
One possibility is that the sound is directly transmitted into the vehicle. This could be done by direct contact of the exhaust to some other component under the car, or even excessive stress of one or more hangers. The sound could be audible directly from the source, which means one or two people observing from different locations in the car should be able to point in the direction that the noise appears to be coming from. One of the more difficult possibilities is that the sound as it is being heard inside the car is an echo. One example of this are sounds that are noticed primarily when driving past parked cars, or a wall, but echo's can often be off of the road too. It requires a little imagination applied to where the sound appears to be coming from. If there is nothing in that direct line, then you have to visualize extending that angle down to the road and then to where it reflects back up to the car.
Tools like Chassis Ears can really help identify the sources of certain sounds.
With the history here, I have to wonder if the mufflers simply don't match the natural resonance of the exhaust. It really is a talent to design a system that is agreeable to hear at all of the different engine speeds and loads. Is there a "tinny" aspect to the drone and does it sound like it is coming directly from the mufflers?
Having the manufacturer custom re-engineer your exhaust system really isn't an option for the typical owner, regardless of what generation they belong too.
Tracing down the drone would be a difficult task indeed. I would def inspect the clamps - it could be transmitted through a clamp that is loose/too tight. Especially, if a search shows other people with the same car/exhaust do not have a drone issue.
Another cheap fix would be potentially working with a muffler shop to design a resonator. It may or may not work.
The long term fix is changing the exhaust - but that would be no fun would it!
As for trying to fix an exhaust drone with a sound deadening....bwahahaha!
The Bad: You are still using the budget Millenial Car blah blah excuse to justify it. This exhaust system was a quirk on your particular car, and not every car in this price range will have such an annoying add-on. So paying to fix the exhaust wouldn't violate your Millenial Car Prime Directive. So just do it, document the costs, and revel in the improvement it makes. That will still be good information for someone looking for that budget enthusiast car.
G8board.com has a great "Almost drone free" thread
