GS27 scratch remover
                    Wondering if anyone's used GS27 "as seen on TV" to
remove small scratches in clear coat. I'm
interested in any experiences/comments you may
have. THANKS!
have. THANKS!
I stoped at a Pep Boys parts store looking for something to cover some scratches, spoke with a worker there that said although he hasn't used the stuff himself, every tube that he's sold (which ammounted to about 5) had been returned cause it didn't work. Considering it's like $10 a bottle, I wouldn't even bother.
There are 2 types of scratches - those that your fingernail doesn't get stuck in and those that it catches in. If your fingernail gets caught, then it is a deep scratch and I would treat it like a paint chip. If your fingernail doesn't get caught then I would buff it with 3M Imperial Hand Glaze a few times until it is gone or less noticeable.
My strategy:
Claying the car cleans the paint very well and quickly, with little or no abrasion. For scratches, I use clearcoat polising compund, a cordless drill (slow enough to avoid burning the paint)with a 5" diameter, 2" thick foam applicator, and buff, buff, buff. Then, I use a polishing compound (Meguiars, etc) and buff again (clean pad). Then Carauba wax by hand. This smoothes the clearcoat, so the scatch isn't white anymore (it's still there, though, just smooth. You can see it in the right light, at an angle). Figure about 15 minutes per scratch.
And, as above, if it's a deep scratch, touch up. But, I use a very fine artist's paint brush (about $3 or more), as it gives better control. And I use it for only 1 session.
of reservations. I used it once with good
results; it covered the surface scratch. Still
dont have much faith in anything they show on tv
but, on the other hand, it hurts my heart to see
scratches on my one year old MPV. Never got
used to put up with scratches or rationalize
about them. I really hate to have to be ripped
off by a bodyshop in fixing it. So there is no
solution to the problem, just suffer.
But, if some magic cream will do the same thing, go for it!
this is still a waste of money though...there are rubbing compounds that work just as good...i still haven't found any "miracle" compound for clearcoat scratches.
It is useless in my humble opinion.Just goes to
show you that 90% of what you hear on TV is lies.
If they ever pass a law against deception on TV
every tube in the country will go black.
