Is a transmission swap possible?
Donii72Donii72 Member Posts: 2
edited March 2016 in Isuzu
i have a 1993 Isuzu Rodeo and a 97 Rodeo. the transmission is going bad in
the 97 but the 93 is fine. i was wondering if i can swap the transmission from
the 93 to the 97. if so how?
Answers
    Engine, transmission, and driveline in each (4wd/2wd)?
  • Donii72Donii72 Member Posts: 2
    both have a v6 3.2L both transmissions are automatic but the 97 is 4wd but not the 93
    Drop by your neighborhood car recycler/junkyard and see if they'll look up your Rodeos in their 'interchange manual'. It should say if the transmissions are the same. Given the years difference, and 4wd vs 2wd, I'd be surprised if they swapped.
