Fuel Economy Update for February — Holding Steady After 30,000 Miles - 2015 Ford F-150
Our 2015 Ford F-150 has amassed more than 30,000 miles, and some 10,000 miles have passed since we found it was overfilled with oil.
People can easily see the value of a turbocharged diesel that has tons of low-rpm torque, for a truck, but they can't see the value of a turbo gas engine that has tons of low-rpm torque AND high-rpm power, for a truck. This engine has the same torque 1800 - 4500 rpm that the Coyote has at 3500. For a vehicle that can tow 9,000 lbs., that would seem to me to have some value.
As for the towing capacity, what most people don't understand about the tow-rating is that it doesn't include the braking capacity. If you load a truck up to max weight towing, your brakes are normally not up to the task. Its why a lot of used vehicles have an issue with warped rotors after they've been used for towing heavy loads. However, my F-150, with the towing package, can tow about that. Close enough to not be an issue.
My main issue is that Ford touts the EcoBoost as the fuel efficient option for V8 Power, with gas sipping economy. But it's not really that way. While the Edmunds F-150 takes a hit for the 4x4 option, it's also got an aluminum body, which should help it. Instead, it's under what I'm getting with a steel body and a V8 on a 2WD.
Twitter: @Edmunds_Test
I've got my own personal, long-term mpg test going on in a 2WD, standard cab, short wheel base, and 3.31 standard rear axle. My F150 with the 2.7 is the second lightest available @ or about 4168 curb weight pounds. Additionally, my truck primary use is a commuter vehicle, but I absolutely need a truck for the weekend projects and for hauling home yard sale stuff and hauling off junk. The 2.7 adds $799 to the base price of an F150, so unlike competitors advanced engines, Ford lets one have it in minimalist configurations and at a small premium, and even if it gets only roughly the same FE as the base engine, all that extra torque, and the RPM at which that torque comes along makes it well worth that extra 800 bucks due to the far superior driving pleasure it provides.
I just achieved my highest mpg tank to date @ 25.4, and this was at least 10% city driving. My worst so far is 21.7, and my average has climbed to 24. Unlike the Edmund's review, I am not reporting any one-direction only tanks, as that scenario should never be reported. I did, however, take notice of one error that Edmunds did not that has slightly boosted my average and that is that my trip meter loses a consistent 1.8% to any GPS, so I add 1.5% each time so as to be conservative in my reporting.
The point I'm making is that this technology can, we mated in a more advantageous way, absolutely blow away any V8 in a similar configuration in a conservative driving style with respect to mpg with similar performance and refinement. I took a chance on my truck with this engine choice, as the diesel options from two other brands were way out of my price range and way more truck than what I needed.
