No crank no start
bulldog71bulldog71 Member Posts: 1
edited March 2016 in Nissan
I have a 2005 nissan pathfinder that will not crank or start. When I turn the key on,the headlights come on but they are not automatic headlights. And in the instrument panel when I turn the turn signals on, they do not come on in the dash but they are working. Any suggestions? I'm at my wits end. Thank you
  • reuben16reuben16 Member Posts: 1
    I installed another body control module in my 2006 Chevrolet equinox and now it won't crank  do I need to have it programmed first
  • thecardoc3thecardoc3 Member Posts: 5,860
    Where did you get the module, and what made you think that the original one was defective? Used GM BCM's usually cannot be reprogrammed to work in another vehicle.
